MX-3_4evr's N/A build part 2!
    antonio-- pulleys got in the shop on tuesday. he's gonna run off the alternator pulleys first. and then i'll prolly end up having to go find some more 5.5 inch aluminum bar stock. not quite enough to get as many crank and w/p pulleys run out.
    as for the oil pump. still gotta find some 4140 bar stock... should figure something out next week.
    and as for the header...design program was just released today. i'll get it tomorrow and get started on designs over the weekend.
    92 Pro - Daily Beater and project- current frankenstein
      ^ Hey man if you need materials to speed up the process let me know! Discount steel has them in stock, and that's not that far from my house. I need to have this car running by May 1st!
      And as I said: Pictars!
      Transmission with Mfactory LSD, taller 5th gear, new axel seals, keyed races, and in/out plugs for an oil cooler! Thanks Ryan (bpt323)!
      Oh and ITBs of course!
        Damn that's gorgeous
          Congrats. Looks good. I'm sure you're already anticipating that joyful noise of first start up.
            looks good. im jealous. i cant wait to build my old block
            1994 Escort LX Wagon
            2013 Hyundai Veloster Turbo
            91 EGT - Junked May 2012
              looking great man, that trans should be a nice addition too.
              What pump are you going to use to move the trans fluid around?
                oh thats right! forgot about that!!
                ok well then in that case...
                check and see if they have 3.5 inch diameter 4140 round stock. one inch of material should make one set of gears. sooo...foot long??
                and then also 5.5 inch diameter aluminum round stock. prolly a foot there as well. yeah deff a foot for that. that will give me 6 sets of pulleys from a foot long chunk of aluminum.
                let me know if ya find anything there
                  Looks great. Like the valve cover color.
                  SPI swapped
                  http://www.cardomain.com/id/WhiteLightning96
                    I can buy the material for my own stuff. Look at what this website got:
                      A little update
                        looks amazing
                          Is that the intake flange I made? How did it work out?
                          --Ferdi
                            --Ferdi
                            Yes it is! It works just like it supposed to. It warpped a little, but that's normal.
                              beautiful setup mane. the ITB's are going to eat babies and small animals. lol
                              '88 323 sedan, K-swapped..
                                Damnit now I need to change again
