Question, is it ok to use the original main bolts? Or should I order ARP ones?
MX-3_4evr's N/A build part 2!
You can re-use them if you're staying n/a, there wouldn't be as much pressure.-Jack
yeah i had the same question to.. looked em up at work and they are NOT torque to yield. i was pumped as hell when i found that out. = cheaper build. lol
revised w/p pulley is done!! looks mighty nice i might say and should deff hold up w/o any problems.
According to computer.....
w/p pulley will weigh .462 lbs compared to around 1.5 lbs stock???
crank pulley - .617 lbs compared to 5 lbs stock?? <-thing is a beast!!! lol
alt pulley...comes in at a whopping .159 lbs. haha
also talked to a buddy bout the altered pulley sizes....he made a good point in that the smaller crank pulley is an advantage cuz it will take less power to spin the alt pulley and w/p pulley via the ratio difference. thought about it and i agree.
here is the revamped w/p pulley.92 Pro - Daily Beater and project- current frankenstein
the stock crank pulley weighs alot more then 5lbs i could almost swear on it.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
if your designing these pulley's.... do design the crank pulley so it can have a bead of urethane or something pumped into the back of it & still maintain some dampening effect- it won't really effect the weight since its made from aluminum anyhow.
I could have these mass produced if im allowed access to the files after complete development & that we know if they fit right or need redesign---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
copied design from Ralco RZ kit antonio got. just making em for myself. but yeah i can look into a groove cut for dampening. how big would it need to be??/ like 1/4 inch wide by 1/8 deep?? filled w/ silicone... that enough???? and does it matter where its cut?92 Pro - Daily Beater and project- current frankenstein
red green or yellow edge????
hope you are talking about the red one. cuz the green circled line is a radius goin up to the red line. i CAN put a radius in place of the red line if that is what you are referring to. have it one smooth flowing contour. but this pulley is almost a direct clone of the alt pulley. almost92 Pro - Daily Beater and project- current frankenstein
