About time I did an update. Car has been running well. Swapped in my Walboro 255, improved 3rd 4th AFRs, but did reveal how it starves with less that half a tank :?
Some other updates I forgot to add:
Upgraded to a proper variable TPS using an automatic BP throttle body. This gives far more linear response and accuracy for megasquirt
And a cheap unused K&N for Mr snail:
I rebuilt a rear caliper, it was quite a chore cleaning it up! It was starting to wear grooves in my discs so was due new seals etc.
Also changed the cam cover gasket as the generic brand one failed after about 9 months use. Mazda OEM FTW!
Still looking clean under there:
Been working on this for a few days, only passenger side done:
Rx-7 FD seat in an Mx-3, horrible task as the mx3 rails are at different heights, spacings, angles etc! Took many many hours of drilling, grinding and welding. Super comfortable, love these seats!
Also replaced alternator with an 80amp kia.
Annual testing:
Got my custom evo8 manifold skimmed flat, no more leaking
Current big project: OEM JDM LSD swap from v6 to i4 G series box.
Ring gear fun
'bout flipping time...
mmm
helical
ARP bolts and nuts
Only identifying numbers:
A beautiful sight:
So the box is all bolted up. Just getting axles ready then it's time to slip the engine out and tidy things up.
Annual testing:
Ring gear fun
mmm
helical
ARP bolts and nuts
A beautiful sight:
