Rice's Epic 323 worklog........
    Originally posted by FE3-323 View Post
    jesus, 312mm??? thats a big disc man
    thats what she said,
    brakes looks good, but it looks like you def need the 312 rotor to take full advantage.
      we need a place that will make larger/deeper brake pads for us that still fit within the OEM caliper. i would sure love to see some 312mm rotors made to fit underneath. altho i think it would likely be too much change in brake bias.
        I think it would be too much.
        I will say there is a noticeable difference with just the 11" Rotors and BG calipers..
        ._________________________
          on the note of welding the brackets to the spindles...
          don't. they are cast. and although you can weld cast, it is not a good idea. at all. the area around the welds becomes a major weak point. also, what are the brackets made out of?
          loves BGs too much for his own good...
            id like to stick the biggest rotor combo i could under 15" rims with a decent sized pad.
            still i would like to get custom pads started
              Thanks for your input
                Started working on installing the GTR intake manifold which has been sitting on a shelf for over a year... Once I removed the intake piping I noticed the driver's axle seal was leaking. Since it is was easier to fill the transmission with the piping out I diverted to changing the seal.
                Seal changed, adding fluid tomorrow and will finish the intake manifold.
                NOTE: Kia G-series axle seals are way better than the MSP ones. The Kia axle seals have a double rib seal where as the Mazda seals only have one. It will probably be okay but the Kia ones are a better design.
                  miata guys proved knuckles are not cast...
                    nate, I believe the ball joint shaft size difference is due to the year, not the lx or dx designation. I could be wrong but I recall reading that before.
                    -Steve
                    94' Protege < Worklog<SOLD!
                    VF10 powered!
                    262 Whp & 257 Wtq
                    13.1@107
                    '02 Suzuki Bandit 600s
                      yeah ball joints change in 91 iirc
                        Yes, ball joint size changes. Autozone (my choice parts store) has different suppliers for their parts, even the same exact part. Not all balljoints bought from autozone are made equal... Ive found the ones made in japan are far superior to the other crap.... They do not rust, have better boots, grease fittings and not made from a ****ty cast.
