All this zoom zoom has to slow down or it will go boom boom so I made a few upgrades.
ATE super blue, speedbleeders, KVR pads from Chris, Goodridge SS lines
During the process, I replaced both front calipers, the both master cylinders, clutch ss line, slave cylinder, and a couple hard lines
No pics of ^^^ parts replaced
Magnetic drain plug from chris
The cam seals were leaking pretty badly, so I replaced them and decided to leave the timing covers off.
Before and after door speakers. The previous owner cut the speaker grill holes way too big.
Waiting to be installed:
MSP Latest revision
Got rid of the Forge POS BOV and stock GTX bypass
New radiator, It needs the lower return spout fabbed. Right now it is about 2" from the DP and will not work
Also will use a gates timing belt when I go to install the water pump
Retrofitted to a 98 ES cd player
The vents I took out...
Working on something. The megasquirt I think
KVR pads F&R
Didn't use the fluid
The HKS SSQV BOV flange before paint.
MSP Latest revision
KVR pads F&R
