yes you can
frogi323's 323/ protege work log
Originally posted by minnesotapjCost of your fancy German built sports car $35k
price of your fancy sun glasses to match your German built sports car $200 dollars
Getting beat by a second hand 20 year old Japanese 4 door... Priceless!The only bummer about the world ending is that you can't turn to the person next to you and say "WOW! Did you see THAT?!!"
look i cleaned!!!!!!
then the wife filled it
any mn guys with a sandblaster????? i need one. wire wheel brush is killing my arm. and it stopped stripping the rust off.
well i am cleaning up the rear disc setup i have..
well the rear discs are coming along nice and slow.
so here are some cell phone pics.
the amount of rust
stuburn bolt, which is still there!!!!!!!!
the experiment with evapo-rust after i wire wheeled the hell out of it.
after soaking for about 2 or 3 days. i pulled it out each day to see if all rust was gone. ie the areas i couldnt get to with the wire wheel.
ready for painting
poof its painted!!!!!
my hand has been smurfed
if you want your brakes to last..... cut several more straight line grooves in that upper slide & grease the hell out of it---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
stupid F'n Pita
Bolt Broke My Table Clamp!!!!!!
So When I Did My Engine Rebuild My Origanal Table Clamp Broke Because Of A Bolt. Well I Got A Used One That Was Better Made. So I Put The Rear Hub In It So I Can Get The Stupid 12" Bolt Out. Well I Took 3 Wacks At It And The Clamps Base Broke In Half. I Barely Hit The Dang Thing. So Thats 2 Clamps In 1 Year. Im Getting A Big One This Time. Or At Least 1 That I Cant Break So Easy.
i give up. im done. give me some c4 and just blow the darn thing up.
i am giving in and buying rear hubs from the yard.
here are the pics
torch!!! & i see what you meant now, i call that a bench vise---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
i torched the heck out of it and to no avail. i torched it 7+ times and nothing. so i found some spindles at the yard for pretty cheap.
so i looked up prices on carpart .com and found that a yard up north has 1 off a tracer and 1 off a escort but the weird part is that the tracer 1 is 35$ and the escort 1 is 20$. wtf? also found out that 93-98 spindles are the same for the protege. and the protege spindle is 40-50$.
also a 91-97 escorts work. and 91-96 tracers too.
im finding this so weird.Last edited by frogi323; 06-07-2009, 06:32 PM.
did you get it red-hot?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
i torched it for 10-15 minutes. it got as hot as its going to. im using map gas.
i have a new idea for the front end. but it will have to wait till im done with the big stuff.
I worked at a wrecking yard for a few years. My advice: Get it red hot, then pour cold water on it. The thermal shock will help you break it free. Sounds to easy to work, but it usually works every time. If not swear at it, then chuck it LOLDominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
