Escort Build Up!!!!
    man this tuning stuff is not working so good for me. im still rich as hell and broke so i cant get it dyno tuned yet........i just want to lean it out alil and ill be good cuz even tho its very rich still running good.
    '95 Ford Escort LX, GTX block .40 over, wiseco 9.1 pistons, gtr rods, gtx head, MS1, 550 inj. T3/T4 .57 Trim, DSM BOV, WALBRO 255 FP, civic half rad, MSP LSD, stage 3 kyclutch, ebay short shifter, mx-3 rear tie bar, AEM wideband....SHE IS ALIVE
    '88 Mazda Gtx AWD B6T engine Ported head, VJ-11, EL prototype chipped ECU, Blitz SBC-iD electronic boost controller, Full HKS exhaust, Centerforce dual friction clutch & more
      well i datalogged 2 runs but its way to big to post.......is there another way to post it or something?
        well today is going to consist of alot of reading........i have till aug 1 to get in tuned well enuf to drive her 2hrs away to th va meet!!
        Wish me luck lol
          i found out i was running way to much req fuel some how i had it set to 8.3 when it needed to be set to 5.5. Now im working on my target afr for the ve fuel table. Can anyone help me with this? im trying to run autotune so i can get the table set. but this MS is kickin my a$$ im trying to learn it but just not getting it all the way yet.
            I'm getting a MS from Lex here shortly..I hope I don't have as much trouble..
            When is the VA meet and where??
              don't use autotune unless your values are already very close. Just make it rich, make a 30min or more drive keeping constant map as much as possible without abrupt accelerations (disable ae, ego correction and overrun) and then just run megalog viewer analyser and it will do the job for you. Then repeat in the same conditions and ambient temperature. Be sure to reenable everything after that and tune your ae.
                va meet is this sunday bro. thanks for the infr 323driver.........im going to the dyno this weds 7-29-09 tho to get it dyno tuned............what all do i need to take or do before the dyno runs? ive never been so have no idea. so if anyone has anything that i should do please tell me! thanks alot!!!!
                  If you're goin' for a dyno, keep in mind they're gonna push your car to the limits. So I'd be sure to have fresh oil if I were you
                    ok fresh oil going to pick that up now i only have 200 miles on the rebuild
                      i would definitely do your first oil change now, as i'm assuming you are still running non-synthetic for break in...?
                        yes sir non-synthetic should i run non-synthetic again for the dyno?
                        now i was wondering if it is really worth me buying a blaster 2 coil for the dyno?
                          She made 203whp and 178wtq at 12psi...............the bov leaked after 10psi so couldnt go any higher sucks but i def know she can prob reach my 265-275 goal.
                          now the bad after leaving the dyno and driving around for 3 hrs the car just cut off while i was going down the road. now when i try and start it the tach dosent move but im getting fuel and alil spark not sure what hapeen????
                            Check all your ic piping.
                              did that she will run with the piping unhooked but thanks
                                i think i need to find a better place to take it cuz she should of put down alot more power i think!!
