Custom Sub enclosure first fiberglass layer results
I let the resin soaked towels sit in a room at 20 degrees Celsius for about two hours before I had to punt the car outside. The resin for the most part dried up. The first sheet got soaked better and is a lot stiffer, whereas I ran out of mixture to properly saturate the second sheet and its a little bit flimsy in some areas. That's not a big concern; I planned to do a second layer anyways. Picture time!
Getting the enclosure out was as easy as removing the tape from the Dynamat and gently prying the mold and plastic off as one piece.
A shot of the spare wheel well with the enclosure removed
The underside once I brought the enclosure into my basement
Peeling off the plastic was a little tricky; the resin mixture didn't harden between the plastic and the enclosure.
I put the enclosure back in the garage next to an electric fan-operated heater. Until I get a new job, no more fiber glassing will take place. I'll cut out the round supports for the speakers and make the divider (each sub will have its own cavity, not a shared cavity) but I can't attach them all just yet.
