Slow and Cheap...
    Got a little more porting done to day. It slow going, my air compressor is just a little too small to run a die-grinder.
    But here's my sweet new work bench!
    I don't know how I worked with out one!
    I started cutting out a new throttle flange for the supra throttle, don't worry Antonio I've still got plans for that mustang throttle.
    And this is what took me most the day. I cut off the little flange that the purge control solenoid bolted to and there was also a TON of casting flash!
    94 Protege LX: HX-35, Megasquit, ect...
    98 Subaru Legacy GT-DD: 1 inch lift, and all the standard N/A stuff.
      More porting. I ran outa propane but I did get the intake ports done.
      In order to get the casting shift cut out, I had to open the ports a little past the gasket.
      So the the intake mani is done till I make a trip welder to get the new throttle flange on.
      The new port out line. To this
      And that's the intake side. It's not the best but it's the best I can do with tools I have available...and it's WAY better than stock. Next it's on to the exhaust side. Then the head goes back on and I have to fab up a new lower radiator hose, put it the meth kit, get the COP's wired in, toss a new rear main seal on, and maybe a few other fun things...
        Nice! Sorry I didn't came up to St. Cloud on Tuesday, I had too much stuff to do at home. I will be coming up tomorrow (1/14/10)
          It's cool..I'll be workin 1-9 today. Stop in.
            What are you doing the porting with? When I rebuild I'd like to do some.
            -Steve
            94' Protege < Worklog<SOLD!
            VF10 powered!
            262 Whp & 257 Wtq
            13.1@107
            '02 Suzuki Bandit 600s
              I'm using an air die-grinder with a rasp for all the shaping and ruffing in. And an el-cheapo target brand dremel for the details. I also used a few files and a 60 grit flapper wheel last to get to get the finish I wanted. And almost a full can of WD-40 to help keep the bits from clogging up and a wire wheel when they did...
                Small update...
                Well between this god damn flu and the super cold I haven't done a damn thing...but I did just pick up a Millermatic 135
                  Niiiice! I need to pick up a nice welding system soon here. Hope you feel better!
                    Hope you feel better soon! That's a nice welder! You need to pick up a spool gun that feeds aluminum lol.
                      I'm over it now but today was cold and I was lazy. The welder is kinda a friend cooperative thing. A friend had a car that needed work and sellin so I did the work and sellin, he bought the welder and it sit a my place. Next up is a tubing bender. Then the spool gun and maybe a fender roller.
                        Fender roller = wooden baseball bat
                        -Steve
                        VF10 powered!
                        262 Whp & 257 Wtq
                        13.1@107
                          Or a fabricated hub device using soft skateboard wheels
                            That's what I said but one of the guys going in on the roller is oprah rich and has about 20g's sunk in his SRT-4 and an other has a RX-7 that's his rolling resume (Wyotech grad). I'm just goin in on it cuz it'll be cheep and it's nice to do things right for a change Plus I'll get a cut of the "rental fee" when we loan it out to other friends
                              True true, I also love your you used that term: rolling resume, because it is true.
                                Ican't wait until I build my garage, then I can be a master mechanic and have all those goodies
                                91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
                                95 Probe SE- Sold!
                                The rest is bone stock.
