Hey crazycanadian. I think I will build a BP powered Protege for STS...good suggestion. Unless you want me to build something else and join you in SMF? Nice to see you having fun in my old car...When do you want that spare KL?
My new whip.. :)
Originally posted by Thomas View PostHey crazycanadian. I think I will build a BP powered Protege for STS...good suggestion. Unless you want me to build something else and join you in SMF? Nice to see you having fun in my old car...When do you want that spare KL?
Finally got my 17's on the car.. stupid jap rims with odd ball valve stems took a while to order in...Also got the mx3 rear seat mounted.. I ended up using some mx3 rear seat belts as well.. I had to modify how they bolted in to fit over the rear strut tower.. relocated the rear tail pipe as well... I extended it out past the bumper.. This really reduced a lot of the droning noise inside the car...
Rims look good1993 Protege LX-Midnight's shadow SOLD
For the Mx-3 rack info-
The Mx-3 GS(v6) is the one with the 3.x turns to lock, both 323 racks, power and non, are a higher turn to lock. BPT323 did a write up on how to de-power the mx-3 rack and gives more specs on the racks themselves than I know off the top of my head.Last edited by Ace; 07-06-2010, 09:25 AM.
Originally posted by Ace View PostFor the Mx-3 rack info-
The Mx-3 GS(v6) is the one with the 3.x turns to lock, both 323 racks, power and non, are a higher turn to lock. BPT323 did a write up on how to de-power the mx-3 rack and gives more specs on the racks themselves than I know off the top of my head.Last edited by crazycanadian; 07-07-2010, 01:04 AM.
yep longest lock to lock is the manual steering racks, then the p/s racks in the 4cyls (protege, 323) and the shortest is the mx3 v6 p/s rack.-Jack
Originally posted by Mazda_Powered View Postyep longest lock to lock is the manual steering racks, then the p/s racks in the 4cyls (protege, 323) and the shortest is the mx3 v6 p/s rack.
Sorry, my mistake. the MX-3 GS V6 rack is 2.75 turns to lock.
heres the thread http://www.wihandyman.com/forum/showthread.php?t=29778
Originally posted by bpt323As the title says... this shows how to convert a power steering MX3 v6 rack with ~2.75 lock to lock turns into a pure manual rack.
Tools Needed:
12mm wrench or socket
line wrench
adjustable wrenches 1 huge 1 medium
snap ring pliers
14mm socket- 1/2" drive
15mm socket-1/2" drive
1/2" extension
1/2" drive ratchet
hammer
bench grinder/ angle grinder/ hacksaw
Hey man, I have the exact same seat in my Pro, the only complaint is that after hours of driving I feel the the lumbar support isn't as good as it should be for me. I'm 6'2 and my head bashed into the sunroof on the original seats, so the MX-3's were a must. I'm thinking of maybe opening them up and seeing what I can do to fix the problem.
Anyone ever done that?
I now have power steering.. yaa! the car feels sooo much better to drive now.. its not such a fight to get it to go where you want it to... For anyone who's playing around with swapping racks.. the 4 cylinder and V6 racks have a different flair design for the low pressure lines and they don't interchange.. I had grabbed a set of V6 lines, but I have a 4 cylinder rack in the car and low pressure line didn't work.. I had to make my own low pressure line in the end..
Took the car out to the track tonight... Wasn't what I was hopping for but then again I have lot of room for improvement..
First run of the night.. I still had my 17's pumped up to 42psi... bad wheel spin off the line..
R/T.... 0.442
60'..... 2.398
330'... 4.819
1/8.....10.192
MPH....69.76
1000...13.276
1/4.... 15.887
MPH....85.72
Second and last run of the night for me... I dropped my tire pressure down to about 20psi.. Still couldn't launch worth a bag of crap..
R/T.... 0.577
60'..... 2.307
330'....6.099
1/8.....10.034
MPH....69.53
1000'...13.091
1/4......15.690
MPH.....85.47
Next time out I plan to take my other set of rims and tires... Even though they are old the Toyo RA1's on the 14's rims will perform better then the federalls I have on my 17's...
