My tall console is broken, remember? Escortfan, I don't have power windows or sunroof, the console is really the only thing I need right now. Thanks though.
Atomic's 94 MX3 RS
perfect! that's exactly what I'm looking for.
you don't happen to have a BP 5-speed driver's side transmission mount bracket, do you? I can't seem to find one anywhere- I have the mount itself, but the correct bracket (the bit that bolts to the transmission) is unobtanium for some reason.sigpic
92 240SX: KA/T25, nerd mobile
Chuck and Eddies in Southington has a BP Pro, the trannys gone, but that mount/bracket is hanging off one bolt. The BP is also out infront of the car
If i understand right then RS means R4 engine not V6 under the hood in the states. Is it B6 or B6D you are trying to turbo?
If B6D then you can plug all B6T parts (injectors, disty etc ) on the B6D engine and use B6T harness with B6T ECU.
If B6 then i did it like this and used stock B6 NA ecu:
No detonation what so ever @0.7bar of boost and was much faster than NA BP
IvarRLast edited by IvarR; 11-01-2010, 02:24 PM.
Get ready for OBTAINIUM because, I do have that trans mount bracket from my parted out GT. I think it's in my spare garage, either that or at my parents, if so it's still connected to the transmission. Let me track it down, and I'll photograph everything, and get you a quote. Need anything else? I have a really minty f2t diverter valve somewhere in one of my garagesCurrent:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
Originally posted by atomicEGT View PostIt's a B6DE, so that's good to know. I'll track down a wiring diagram for the B6T and see if I can just re-pin the harness.2011 BMW 128i 6 Speed Manual -- dd
1990 Protege 4WD 5 Speed
Originally posted by CODY004WD View PostGet ready for OBTAINIUM because, I do have that trans mount bracket from my parted out GT. I think it's in my spare garage, either that or at my parents, if so it's still connected to the transmission. Let me track it down, and I'll photograph everything, and get you a quote. Need anything else? I have a really minty f2t diverter valve somewhere in one of my garages
Originally posted by nerd racing View Postyou might have to clearance the engine block for the B6T stock turbo/manifold to work, for some reason the B6D that came in the MX-3's had an expanded web instead of the normal B-series profile. I'll see if I can find the link on MX-3.com about the topic.
Originally posted by CODY004WD View PostLike a true hoarder:
1. I know where I keep my ****.
2. Unobtanium, is totally obtainable.
$40 shipped sound good?
[IMG]http://i265.photobucket.com/albums/ii208/cody004/P1030045.jpg[IMG]
[IMG]http://i265.photobucket.com/albums/ii208/cody004/P1030041.jpg[IMG]sigpic
IvarR
that's assuming I use the B6T disty though, right? I know they're different, but if the wiring is the same, I'd keep mine... the goal is to use as much of the stock stuff as possible, and keep it more or less reliable. I'll only be running .6 bar or so- no need to be greedy, considering I'll have the beast as well.
I'll likely be comparing wiring pinouts at work tonight if I can find them, that should give me an idea of how this is going to work out.sigpic
Originally posted by atomicEGT View Postthat's assuming I use the B6T disty though, right? I know they're different, but if the wiring is the same, I'd keep mine... the goal is to use as much of the stock stuff as possible, and keep it more or less reliable. I'll only be running .6 bar or so- no need to be greedy, considering I'll have the beast as well.
Also my coworker/garage-mate uses F2T ECU and sensors/afm etc on his car @ 0.8-1.0bar with no problems.
IvarRLast edited by IvarR; 11-02-2010, 06:42 AM.
oh no kidding, that's pretty cool. to adjust the AFR with the AFM I'd have to swap to a VAFM, mine's a MAF (like the 1.8 Miatas use)... though I may have to anyway just to get it to work.
I think I know where I can find an F2T ECU cheap, I'll have to look into that as well.sigpic
