best sparkplugs for a protege
    Officially the oldest thread ever bumped.
      I am currently using autolite copper spark plugs. I bought them from car quest, but you can also get the same plugs cheaper at WalMart.
        Is it a 1.8L pro? NGK BKR5E for N/A BP. I use NGK BKR7E for my turboed BP.
          BKR6E-11 is what i used to run on my non turbo BP's
            lol I didn't even see that... are you surprised it was a girl that did the 7 yr old bumping? J/K
            There are no stupid questions, just stupid people.
              Can anybody say what is different between BKR5E and BKR6E-11?
              My BG Familia FE3 project full spec and plans.
              www.mazdasgarage.com/forum/ New mazda tuning forum
              1/4 mile drag with BP DOHC engine:
              Reaction: 0,5771 (not so bad)
              60 ft: 2,472 (good for conditions what was)
              ET: 16,2411 (but was heavy wind from front and custom intake was just compleated in nigt and setings was worst than bad )
                Never use anything but NGK or Denso in japanese engines, which are OE brand plugs. Some people get away with cheap plugs but I have seen too many problems with random misfires and running like crap when people cheap out on spark plugs like autolites or think they are upgrading running Bosch platinum whatever. A perfect example is a Celica GT-S with the 2ZZ-GE engine. It will set a check engine light if you install anything but OE plugs, and that includes even the most expensive Bosch plugs.
                Save the Autolites for your domestic small block boat anchor.
                FS Forged H beam rods
                awaiting test fit
                Aluminum CAS/Distributor caps
                BP oil jet eliminators
                EV14 fuel rail spacers
                More stuff coming soon.......
                  BKR6E-11 is one heat range colder. In NGK plugs, 6 is one heat range colder than 5. The number after the hyphen represents the electrode gap (11 = 1.1 mm).
                  In Denso plugs, 16 is equivalent to NGK 5, and 20, one heat range colder, is equivalent to NGK 6.
                  Absolutely, I couldn't agree more.
                  Happy Motoring!
                    So for my original pistons engine can I use BKR6E or I need use BKR6E-11? different between they are?
                      honestly I don't know, I've never seen a non 11 plug...
                      oh wait
                      check this out I just found an awesome guide.
                      From the guide, I think that if you get the ngk bkr6e, it just means they're ungapped.
                      The number after the model represents the gap size.
                      nick
                      http://www.ngksparkplugs.com/docs/te...tnumberkey.pdf
                      Posted By: Wheresthericego
                        BKR5E: V-Power, nickel alloy type with an .9 mm (.035") gap. Not listed for use in any Mazda. Other than the gap, same dimensions as BKR5E-11.
                        BKR6E: V-Power, nickel alloy type with an .8 mm (.032") gap. Not listed for use in any Mazda. Other than the gap, same dimensions as BKR6E-11.
                        Mazdagirl, use the correct -11 plugs with a 1.1 mm gap which are meant for the Mazda Proteges and clones. Neither NGK nor Denso plugs are meant to be re-gapped; that's why they're made in a variety of electrode spacings.
                        Both the BKR5E-11 and the BKR6E-11 plugs also have equivalent precious metal electrode types (platinum and iridium/platinum) if you're looking for a longer-lasting, higher-performing spark plug.
                        Happy Motoring!
                          Now choised colder BKR6E-11, but need new wires to because 4. cylinder wire are damaged. NGK mayby not the best choise, friend was buy and 2 was with deffect. What are the good 5 wire kit? Hope that not to much OT.
                            Mazdagirl, I'm surprised the NGK wire set was defective. They are a quality product, have a good reputation and are used by many here without problems. Is it possible that it was just one defective sample?
                            I use Magnecor spark plug wires. They provide excellent performance and are very long-lasting due to their construction but they are quite expensive compared to the NGKs. I don't know if they would be available in Estonia but in case your interested I'll provide the website:
                            Happy Motoring!
                              More good wires what somebody use?
                                NGK or Magnacore. Pretty much anything else won't last long.
