best sparkplugs for a protege
    Taylor Thundervolt Wires FTW
      I've heard good thing about Taylor wires but haven't tried em myself.
        i bought taylors when i first put the car together, they are still working fine. i like them.
          I'm probably going to get blasted for this, but....I had good luck from Bosch wires back when I had a BG. Of course, I haven't used them in four years, so I can't really say what they're like now. I just know I didn't have issues back then.
          1995 626: daily beater, mostly stock. Future NASA racer?
          Next up: Speed6 or RX-8
            so advance auto doesnt carry bkr7e anymore. autozone does not either where can i get this plug at any suggestions i still have napa and tropical on my list
            MY DRINKING TEAM HAS A RACING PROBLEM
              Happy Motoring!
                part number 4644 they stock them at my local advance auto...
                  They can atleast get them. Like he said the pn is 4644. Just tell them the pn and have them order them. They should be under 10 dollars. Also try napa.
                  "Who Dey"
                    well this might throw everyone off but ive seen alot of these e3 spark plugs supose to be the best anyone know of there any worth to them?
                    i am kakarot
                      they're **** from what I've heard. NGK is suppose to be what the japan cars love
                        Yeah, those look like more snake oil to me. Stick with NGK or Denso.
                          ngk plugs, now can i run a base bkr5e-11 or do i need higher, i just running a stock 1.8l sohc...+ nowhere around here carries ngk or magnecor wires that i can find, im looking into some autolites or accells, anyone who has used these have and praise or complaints???
                          i am kakarot
                            You can get Magnecor wires from Corksport and NGK, wires and spark plugs, from: http://www.sparkplugs.com
                            Happy Motoring!
                              autolites suck in the B8! I like the NGK iridiums. car runs much better on NGK's & the IR's lasted over 4 yrs!
                              94 pro base model, all synthetic fluids, s/r struts, front & rear ebay upper strut bars,front & rear tie bar, ZX2 1" front swaybar, EGT 21mm rear sway bar, custom delrin endlinks front & rear, custom delrin rear swaybar mount bushings, EBC front blanks & redstuff pads, CS ss brake lines & dot 4 fluid, big drum brakes in rear (from ZX2, free parts), 2.25 custom exaust w/magnaflo oval muffler, 4-wire o2 sensor, custom ram-air, 4-wire BP tb, MSD super conducter plug wires, MSD Blaster SS coil, NGK iridiums,OEM weighted shift knob, ebay short shifter, bronzoil bushings, CS ss clutch line, custom air splitter, mx-3 recaro drivers seat, EGT foglight switch, 35w 5000k hi/lo hid's
                              soon:
                              lightened flywheel & clutch; in garage,
                              Miata Daisy's; after new tires
                                stay away from denso... they are real cheap...i put new ones in and the metal tab just fell off in my cylinder 3k mile after a rebuild. i had to do it all over again. i run bosch and have never had any issues, not only that but they last longer.
                                Originally posted by minnesotapj
                                Cost of your fancy German built sports car $35k
                                price of your fancy sun glasses to match your German built sports car $200 dollars
                                Getting beat by a second hand 20 year old Japanese 4 door... Priceless!
                                The only bummer about the world ending is that you can't turn to the person next to you and say "WOW! Did you see THAT?!!"
                                *1. 85 accord hatch r.i.p. *2. 87 chevy s-10 r.i.p. *3. 91 dodge daytona r.i.p. *4. 91 labaron r.i.p. *5. 91 mazda 323..sold *6. 89 silverado sold *7. 94 mazda protege ...in the works...
