pro or 323
    put the battery in the trunk!
    2006 Mazda 3 hatchback manual
      put the engine in the trunk!
        LOL!!
        ome on guys lets give him a reasonalbe answer
        Look the closer to a 50/50 split you have in weight the better the car will handle. the sedan has a better split than the hatch, because there is almost nothing over the rear axle in the hatch.
        When you turn your car on... does it return the favor?
        Originally posted by goldstar
        Yes, still have it. It was my attempt to immortalize you in verse.
        A Protege driver named Brock
        So his engine he goosed
        With much too much boost,
          Originally posted by Protoss
          LOL!!
          I meant it as a serious suggestion to put the battery in the trunk!
            Couldn't u add weight to the back of the car to get it alittle better handling? say weld a beam somewhere in the back ..
              LOL!!
              50/50 is not as important on FWD cars. Mostly because you want weight over the front wheels to help traction for turning. On RWD cars 50/50 is much more important
              Dan
              dreesemonkey
                on FWD somehting close to a 50/50 split is better than say 70/30 split. granted you you do need weight over the drive axle, but the placement of the car's centroid is more important in a inscance of angualar acceleration (ie turing). if you can have the C of G centered between the 2 axles it allows for a better distibution of forces.
                in a drag strip, and stright line performance, yes you want as much weight over your drive axle.
