ok.. when you slowly rev it revs fine... you let go, then rev immediately after, it has to think about it... also when i'm driving and i put my foot down on the gas, it pauses like its dead or something.. then slowly kicks in.. plus when its shifting thru the gears, its studdering.. like its not getting enough juice to accelerate. I'm getting a hold of a digital camera that has streaming video and sound.. you'll be able to watch me rev it and hear how the actual action is delayed.. its not right.
z5 turbo finished.. some problems i need opinions on....
I believe that i know what the problem is
When u rev, the car goes on boost and the blow off valve is closed
When u release the accelerator and blow off valve opens to release the pressure backed up between the throttle plate and the compressor. This is where the problem comes in. the next time the blow off valve closes is when it reads boost until then the valve is open. the problem is that with the valve open the engine is sucking in air that is not being measured but the air flow meter, as it is seen that u have the air flow meter mounted before the blow off valve. It is know that some type of piggy back computer that alters air flow signals to the ecu will cure thisAssumption is the mother of all fcukups
I beleive that it should be after the BOV so that computer can accurately sence the amount of air entering the engine. I had mine mounted after the BOV, but i wanted to try mounting it where u have it cause i beleived that it would allow for a better air flow, but i never got a chance too. However i am also not sure if pressurised air is the best thing to flow tru the AFM. Do u have any kind of piggyback ecu system. with a piggyback system when u lift throttle it gives u a loud back fire because at that point when the air is released there is excess fuel in the systemAssumption is the mother of all fcukups
