323 v6 swap
    cool, thanks dude.
      hello i have a little problem i was thinkin to use the v6 engine harness from the car i tok the engine from a 323f 95 to 98 but the connectors to the instument panel in the dashbord and the fuse box in the engine bay is diferent.
      and i was wondring if i get a mx-3 v6 enginen harness will that be plug and play to my fuse box and my instruments
        well if you own a first gen, you'll need a 92-96 mx-3 V6 wiring harness, that harness will plug and play.
        also, if you're using a 95-98 engine, there's a good chance you'll need to snag a couple parts of the 92-96 engine to allow the harness to connect to some sensors on the engine.
        hope this helps
        JACK
          okey thanks for the help
            hey have one more problem whit my rigth axle i have the outer axle but not the inner so i wondering if i could use a another axle from a ohter car
            this one rigth side sorry for the big picture not my engine just fund this on the nett
              you'll need a set of mx-3 axles to make this swap work man.
              JACK
                yes i now i have the left side axle and the outer right side but as you see is the right side axle to pieces and i missing the inner won.
                  and i have heard at i can use anhoter axle from a diferent mazda but i not sure wich one
                    You will need the mx3 halfshaft as well, u "MIGHT" be able to use the prbe/mx6 one, but im not sure. But if u hae to get one might as well get the mx3 gs one.
                      i found one today i had to drive 3 hours each way to get it.
                      only problem i have to find it is becues this cars are very rare in norway
                      but i found one
                        ooh ok, put your location in your avatar... mane...
                          do one of you guys wheres this wire goes to and how the contact look like
                          this is the wire that comes out the white plastic
                          thes wires is located on the left strut tower rigth next to the transmission bushing
                            yikes, no clue man :| i have no idea what thats even for...sorry dude, hopefully someone can help you.
                            JACK
                            good luck.
                              looks like one of the fuse box wires, that connects to the bottom of the fuse box..
                                was gonna be my guess.
