most engine lights are not run through the ECU. The check engine light is the exception.
The TPS is not causing your problem, I ran a 3 wire tps on my GTX for a while without problems. Check your fuel pressure and injectors and the injector harness if you did any splicing leading up to it.
Also check the VAF connection.
