FE3 vs KLDE
    a t3 BP will be far faster then a KLDE. @ that point it becomes a downgrade
      is it me or does chris change his mind faster than a hooker takes her drawers down??
      Check out the Pics
      http://www.wihandyman.com/forum/vbpi...?do=view&g=228
      Mazda's Rule Honda's Drool
        chris is something 1 off idk if he takes estrogen pills or what, but somewhere in that mind of his theres a blonde female running the decision making process.
        Mad love chris in a non way. Drop a FE3 in there
          I deserve the **** getting thrown at me lol. I am worse than a woman in a shoe store.
          Oh yea ryan. Someone said that there would probably be hood clearence issues in the fe3 swap. Any word on that?
          Also if I put a t3 on the bp then swapped in a v6 yes technically it would be a downgrade.........untill that t3 gets bolted to the v6 . This is all just up in the air right now because next year we are hopefully geting into a house and the black car will get parked in the winters and a beater will take its place. At that time then I will make up my mind as to which direction I'll go with it.
            FALSE. My boy already put an FE3 in his protege with the mounts i'd say a good 70% done but no tranny attached and hood closed fine. Project never finished tho and he stuck with a BP.
            Deja Vu has tons of info on it i believe.
              this is what i plan on doing after i sell my hatch. pickin up a 94lx from somewhere southern (no snow = no rust). then doing a KL08 w/ KLZE heads/intake manifold and slappin in my 60 trim T3
              but you're already boosted. so just keep adding more boost.
              JACK.
                KL08 is what exactly?
                  IIRC its a klde mx6/probe 2.5 v6
                    yea people just label the kl08 as a klde for some odd reason? idk why. cyl head code says kl08 lol.
                    JACK.
                      mazda & thier various codes lol
                        you're tellin me
                        i think kl08 with klze heads would be a killer setup for boost though. should get around 160whp just in n/a. Then add my 60 trim t3 well that should be able to spool it quiet nice. stock internals = no reving past 7k tho LOL.
                        JACK.
                          Originally posted by Mazda_Powered View Post
                          you're tellin me
                          JACK.
                          just remebr to swap out the KLZE retainers for the KLDE ones, even the DE's can break but are less prone
                            really? KLZE retainers suck? how did you hear about this one? hmmm.
                            JACK.
                              reading up on the swap for my 323 over on probe talk
                                wtf is a kl08? Ive never heard of such a thing, and ive messed with the v6 for a good while now.These are your motor options:
                                KLDE/KL03=usdm probe 2.5L(de heads, cams,intake,9.2:1 compression) 164hp
                                KLZE=jdm 2.5L(ze heads,KL31 cams,ze intake, 10.2:1 compression) 200hp
                                KLDE/KL03 2.5L usdm milennia(ze heads,curved neck ze intake, de cams, 9.5:1 compression) 174hp
                                KFZE=jdm 2.0L(k8 heads, ze cams,ze intake,10:1 compression) 170hp
                                K8=usdm mx3 gs 1.8L(k8 heads, k8 cams,k8 intake, 9.2:1 compression) 132hp
                                chris, id suggest picking up a milennia motor like i did.Its not to far from a full ze, plus i picked mine up for $116 at a pick and pull.You already know my stance on which direction you should go, ive been trying to sway you for a couple years now.Not to be a dick, but im sick of people that try and compare an n/a v6 to the boosted bp.Youll make more power, with less effort with the v6, and youll be guaranteed to make more torque.You show me a bp that makes 298whp and over 300wtq at a whopping 8psi.Not to mention, youll never be able to make a n/a bp sound mean.
                                93 Escort Wagon V6-SOLD
                                91 Escort Wagon V6-SOLD
                                93 Escort Gt V6-SOLD
                                90 Mazda 323 SE V6-SOLD
                                93 Ford Ranger Splash-Its Baywatch time
