FE3 vs KLDE
    What years millenia? There's a 96 at the jy, and I've been wanting to pull the motor for some time, if it was the right one. (too many variations of the kl make my head swim to identify the right one).
      I know your stance Clint. Lol. You're the guy at the party "have a beer. Just 1. Come on. Pussy." "Ok just 1 though" "here have another" lol peer pressure mofo.
      I've decided that whatever swap I do will not get done till I get a house and a beater so I have time to do the **** the right way the first time. I'm leaning towards the de swap though. Just for easy and more access to parts.
        not all millenia motors have ZE heads just as a warning
          they do if they are the 2.5L.Im not talking about the crap supercharged KJ motor.
          93 Escort Wagon V6-SOLD
          91 Escort Wagon V6-SOLD
          93 Escort Gt V6-SOLD
          90 Mazda 323 SE V6-SOLD
          93 Ford Ranger Splash-Its Baywatch time
            ive seen 2 millenia KLs that were not KL31 heads. just keep ur eye out you'll see what i mean
              might be replacement engines in them ryan. all millenias come with a de-tuned KLZE.
              JACK.
                im telling ya they didnt, how come no one listens
                  Originally posted by escortluver19 View Post
                  wtf is a kl08? Ive never heard of such a thing, and ive messed with the v6 for a good while now.These are your motor options:
                  KLDE/KL03=usdm probe 2.5L(de heads, cams,intake,9.2:1 compression) 164hp
                  KLZE=jdm 2.5L(ze heads,KL31 cams,ze intake, 10.2:1 compression) 200hp
                  KLDE/KL03 2.5L usdm milennia(ze heads,curved neck ze intake, de cams, 9.5:1 compression) 174hp
                  KFZE=jdm 2.0L(k8 heads, ze cams,ze intake,10:1 compression) 170hp
                  K8=usdm mx3 gs 1.8L(k8 heads, k8 cams,k8 intake, 9.2:1 compression) 132hp
                  chris, id suggest picking up a milennia motor like i did.Its not to far from a full ze, plus i picked mine up for $116 at a pick and pull.You already know my stance on which direction you should go, ive been trying to sway you for a couple years now.Not to be a dick, but im sick of people that try and compare an n/a v6 to the boosted bp.Youll make more power, with less effort with the v6, and youll be guaranteed to make more torque.You show me a bp that makes 298whp and over 300wtq at a whopping 8psi.Not to mention, youll never be able to make a n/a bp sound mean.
                  First off "KL08" is a stamp on the K8 heads and cams. And if you would like I will show you a pic for proof. Next the quote"KLDE/KL03 2.5L usdm milennia(ze heads,curved neck ze intake, de cams, 9.5:1 compression) 174hp" does NOT have ZE intake it is completely different /w a longer TB neck and Different vris points.The valve train is the same as the ZE in the sense it has the larger intake ports but the ZE heads still have a slightly different design/w better flow. And if I was dropping in a KL motor into your car it would have to be the KLG4, /w stock: coilpacks, solid lifters, better IM than even the ZE and lighter forged crank /w about 175 - 180hp oem.
                    And Ryan you are right in a way once again I can provide pics for accual proof.
                    USDM Millenia motor: Millenia KL47 heads, IM, TB, 9:5:1comp /w KL01
                    DE CAMS!!!!!!
                    JDM Millenia (curve neck) motor: KLZE KL31-1a1 heads, curve neck ZE IM, 9:5:1 usdm pistions, and guess what still KL01 DE usdm CAMS!!!!!!!!
                    JDM MX6 motor (straight neck) : KLZE KL31-1a1 heads, Straight ZE IM, High Comp pistions, And True KLZE KL31-101 High lift CAMS!!!!!
                    SO this means only the straight neck ZE Is a "TRUE" KLZE The curve neck one is just a USDM Millenia motor /w a slightly better IM thats it!!!
                      KL FIGHT
                      im in
                      my MS8 Japspec KL engine
                      100% IDENTICAL to the MX6 Jap spec engine
                      1996 ST205 Toyota Celica GT4 | 1991 BG 323 Astina GT, BP N/A 138WHP *Gone*.
                      1990 BG Ford Laser S (jdm), soon to be 220whp KL-ZE track hack
                        whats this KLG4 you speak of?? any external links on this???
                          crap, i've been saying kl08
                          me = to high, or not high enough. i knew it was KL0_
                          JACK.
                            The KLG4 Is a KL Motor that comes in the 98-02 usdm 626's It is far better design then even the klze, as I stated above. Well only thing it lacks is the high compression. coilpacks, solid lifters, better IM than even the ZE and lighter forged crank I mean come on just far more advanced and loves boost!!!
                            Theres a guy on PT making 317whp on 8psi on a Stock KLg4!
                              who?
                              i know what of the sean/shaun/shawn 's down here has one in a red probe
                                quite informative, how do the KLG4 heads flow VS kl31 heads? or are they the same? what about cam specs?
