hrmm. wish i knew more about this.
Goin' Megasquirt (My progress thread)
It also errors when I try to reflash it for msns-e. I don't know what's up. I checked the polarity of the diodes at least 7 time, fix a few cold joints, and fiddled with the 2 pots...nothing. I also try to put a help post up on the megasquirt forums and it got deleted and my user account is now suspended. WTF!!! I still haven't herd back from any of the admins as to why.
So PLEASE HELP!!!!
94 Protege LX: HX-35, Megasquit, ect...
98 Subaru Legacy GT-DD: 1 inch lift, and all the standard N/A stuff.
The pots are for VR tach input ... you should use hall/opto input for the BP.
Check and test each circuit, not just the diodes as it states in the megamanual build guide. Especially check the opto isolator circuit.
The problems you are getting could be so general I am not sure what more specific advice I can give you.
got till sunday I want to see MS running---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
you sitll plan to come even if this isn't working right??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
