it will be close to the 70's range unless something wierd is going on, like your rotor is on wrong or you are using some sort of freak distributor.
to me it sounds like you have too much ignition advance while cranking, and thats why its stopping it dead like that. take a look at my ignition map... the boxes at the lowest RPM bin near 100kpa. i use "calculated" spark angle while cranking, i think they are set to 8* or something like that.
