ya its runs like a champ now... I didnt pull nothing out but the airintake... They did installed in a stupied place... well when my exhault is warmin up a weird smell comes out... My car and werid smells the ac does and now my exhault....hahah
Well i did about everything to told me too... I changed out sparksplugs, wires, CHANGED oil, Fluish the Radior, CHanged the rotor withe distributor and bought a new pvc value and CHANGED OUT the FUEL FILTER that was a bitch to do but It all went well...
Yeah the fuel filter sucks to change out. I was soar the next day cause I had to twist in ways my body didn't like. Maybe the mazda people think the buyers of their cars are yoga masters.
I've been using the OEM filters. At my last oil change, however, I switched to the Mazda 626 V6 filter. Identical specs as the OEM but ~ 20% larger in volume.
02 DX Millenium Red
I seem to recall reading somewhere that the oil filter for certain Corvettes will fit, and they are about twice as big.
A larger oil filter doesnt effect the pressure at which the pump operates, but I see what your saying...
The larger oil filter would be less restrictive and allow more oil to flow through the filter in turn making the pump have a more readily supply of oil. I would assume that there is probably a small drop in pressure, but probably not enough to have an adverse effect on the system.
any fluid dynamics guru's wanna take a stab at it?
depending on the amount of difference in the overall system, the oil pump could be working harder to maintain a proper oil pressure. But then, I am not a fluids expert... I should ask the wife, she's the engineer.
I have read a lot of pros and cons about Lucas Oil stabalizer...and one thing I have noticed is that anyone who doesn't reccomend it...hasn't used it. And that all who like it....use it!!! Well I am one who uses it! I have a 2004 Mazda 6 five door with 25,000 miles. Its the four cylinder and I have both loved it and hated it. Hated it because going into an first gear and then reving into second has always been a chore and quite frankly...not a lot of fun. It always seemed as though the gear set up was not supported by enough HP or tourque. I was in the auto parts store several weeks ago and saw the Lucas sitting on the shelf remembering a mechanic telling me a few years ago about how good this stuff was. What he explained that I havn't heard too many people talking about was not its thickness which is what everyone seems to be so afraid of but how the oil stabilizer has more 'Volume' than regular oil!!! If you pick up a bottle of the stuff you will first notice just how light it is. That may explain why it runs cooler...and believe me it does. Since I have been using this product it has all but eliminated the gears 'glogging down' in an effort trying to gasp for more HP. The car is much quicker and all gear changes are much much smoother. I can literally feel the engine giving the gearbox more. I stay in third and fourth much more than I used too because the engine doesn't feel as strained if not at all! 'Lucas' seems to pressurize the cranck case producing more with less effort. I mean if you love driving...you can actually feel the difference!
So the bottom line for me is...this stuff is the ****. Lucas Oil Stabililer has made me love driving this car...not just for its handling, but for its quickness...for the very first time. I have yet to read anyone who has said this product has damaged thier car....not one. So if you love driving and want the most out of your car and want to stay out of the dealership getting your car fixed...(no wonder they would tell you not ot use 'Lucas')...give this stuff a try! You will love it!!! I tried other stuff that I won't mention and almost gave up. Lucky me!!!
I have read a lot of pros and cons about Lucas Oil stabalizer... snip ...give this stuff a try! You will love it!!! I tried other stuff that I won't mention and almost gave up. Lucky me!!!
At first I thought you were selling the product you seem soo enthuisastic (sp?).
Were you using a full synthetic motor oil on the 6 when you were having problems?
Alot of the symptoms you describe are transmission related, and an oil additive will not make them go away. Also, a different oil will not add any performance to your car. Granted it could be sluggish from *not* having a regularly scheduled maintenance, but adding an oil additive like Lucas will not result in added power.
More than likely this is the feel of the buttDyno, and an increase in BuHP. BuHp (butt horsepower) is brought on by the effect that you added something and bought the marketing behind it. Since you spent the money on it, it must do as the advertising suggests.
I used to work for a SCCA competitor that ran in the Miata A-spec class, and in a few other races, and he gave up on the Lucas line of products after no additional benefit was found after an engine was rebuilt. He would rebuild motors every 20k to keep them fresh, and the Lucas made no difference in the few that he had me work on.
I agree completely with everything D323 just wrote. If you go to the Lucas website www.lucasoil.com and read their material, you might conclude that Lucas Heavy Duty Oil Stabilizer is some kind of miracle fluid capable of solving every lubrication-related mechanical problem known to man.
Lucas characterizes this product as "a pure petroleum multi-use oil supplement. Controls noise, heat and wear in manual transmissions and differentials." They go on to say, "Lucas Oil Stabilizer is a 100% petroleum product formulated to eliminate dry starts and reduce friction, heat and wear in any type of engine. It allows motor oils a higher degree of lubricity which reduces oil consumption and operating temperatures. Use Lucas Oil Stabilizer in gear oil to stop leaks, reduce operating temperatures and incease the life of the gear oil. Since it is pure petroleum, it can safely blend with all other automotive lubricants, even synthetics, ATF and mineral oil. It keeps old engines alive and new engines new."
Well, it's good to know that Lucas is a "pure" (as opposed to an "impure"?) petroleum product as no one would want to put a corrupted or unclean product in their Protege. We're all aware that the constituents of and requirements for engine as opposed to transmission oils are somewhat different, and in some cases incompatible with each other, and one usually cannot be substituted for the other. Yet, Lucas claims their stabilizer is suitable for improving lubrication in both environments. I somehow doubt that an additive designed to improve the extreme pressure qualities and desired slipperiness for synchro engagement of a transmission oil can at the same time be optimized for improving the quality of an engine oil.
While it's certainly true that Lucas additive can blend with synthetics, why would anyone want to? Blending the two would dilute the synthetic and remove from it some or most of the qualities that make it superior to mineral oil in the first place. In effect, adding Lucas to a synthetic first degrades the oil but then more than more than makes up for the degradation by adding to the mix the magical properties of Lucas MINERAL oil? Not bloody likely. Additionally, we're all aware that all brands of oil specifically warn against mixing in other types of additives as they may be incompatible with those already in there and can consequently be problematic. All brands of oil, mineral or synthetic, have their own individual additive package to begin with.
Lucas states that their stabilizer will stop leaks. If that's the case it may be nothing more than a viscosity improver that reduces oil loss but may reduce oil flow at lower temperatures which is not necessarily a good thing.
Lucas also makes, Lucas Pure Synthetic Oil Stabilizer that can be used in place of their regular Heavy Duty Oil Stabilizer. Since Lucas provides no information as to its constituent base stocks, just how pure or true a synthetic oil additive this product really is lies purely within the realm of our imaginations.
But wait, I've saved the best for last. You don't even have to wait for a specific amount of wear to occur before you start using Lucas Oil Stabilizer. Lucas uses it in brand new engines. They recommend one quart of stabilizer be added each time the oil is changed. They state that you can "go at least 50% longer between oil changes and your engine will last much, much longer."
If you've read the foregoing, I think you, too, will agree that Lucas Heavy Duty Oil Stabilizer truly is a miracle fluid. Or perhaps it should be renamed Lucas Heavy Duty Snake Oil Stabilizer. As Fox news says,I report, you decide.
One thing that Lucas says I believe to be true, however. It does allow a higher degree of lubricity. In this case the lubricity of your wallet as you note how smoothly and friction-free your money passes from it as you purchase their stabilizer.
Happy Motoring!
Happy Motoring!
Just like I said...those who doubt it...have never used it! And please...don't attach the small cost of this product with there marketing...I tried other stuff including synthetic oils....nothing else worked. I am 45 years old and grew up up in a city full of cheats and con artist. I simply gave this stuff a try and eveything as I stated is true....period...full stop. Now I dare you to "friction free", fork over the less than 10 bucks that would seem to obviously break your bank and try this stuff. It has worked for me and as I have learned, it has worked just as well for many others...."friction free"......that was cute!
