i'd stick with white!
DeeAOne's BF KLDE Swap.
The black is nice when it's all new and shiny but when it starts getting nicked and scratched the white will stick out like a sore thumb..my .02. Hit it with a good primer after you have thoroughly cleaned and degreased it and then roughed it up with a scotchbrite pad. Put on multiple coats of a black primer and then put on the top coat..use a satin finish IMHO. That should be sturdy enough. Take your time for a lasting job.
Clay
Originally posted by monoxidechild View Postknow any graffiti artist? my dream is to do a full graffiti bay.
'88 323 sedan, K-swapped..
leave it white. i love the look of my engine bay91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by Evilist View Posthave you tried fitting the BF rear gearbox mount on the 626 transmission??? i really really wanna know if the whole bracket/mount fits on there
pics as things go!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
its in by itself! need to finish a few things on the front and side mounts but the rear bolts up perfect! i was wrong about the rear mount. the stock mount slid right on to the transmission! the way it looks right now i can use my stock crossmember and front/rear mounts.
rear
the problem mounts
