B6T festy build thread
    Throw ITB's on it.
    My Hiroshima Screamer
      This is too awesome, me and my buddy were talking about doing something like this, not that extensive but you make it to where i want to lol. but its just his daily. Keep it up can't wait for the finished product
      Not What you build, But HOW.
        Originally posted by 323GTX-RSA View Post
        Throw ITB's on it.
        I actually have a set here that I might use haven't decided yet.
        Thanks man
        Sent from my C771 using Tapatalk 2
        12 cbr250r: daily ride
        01 saab 9-3: daily
        98 gsxr 1100: for sale
        93L: money pit/ space waster
        92GL: low and slow beater
        90?: the rust free shell
        89L: for sale
        89L: parts
        76+80 vw dashers: for sale
          Might weld a plate in between the two pieces but its mostly done.
          01 saab 9-3: daily
          89L: for sale
          89L: parts
            i would add a plate in between. but it looks good. got a better angle from the back side of the slave cylinder?? i wanna see the clearance there :D
              sweet! looks good! I agree tho, should box the front up.
                Its barely touching and I need to clearance it. Ill do it when I add in the plate.
                These showed up a few days ago.
                Really needed a break so I put all of my customer stuff on hold and worked on the mounts again. Got the back done and figured out a plan for the passenger side.
                01 saab 9-3: daily
                89L: for sale
                89L: parts
                  Just need to trim the tube a little more then weld it up.
                  01 saab 9-3: daily
                  89L: for sale
                  89L: parts
                    aaaaand they're done.... again....
                    01 saab 9-3: daily
                    89L: for sale
                    89L: parts
                        Opinions? Im wondering if I should eliminate the link at the control arm and just weld the traction bar directly to it. I think that if I left the link in, it would let the control arm twist and bind.
                        01 saab 9-3: daily
                        89L: for sale
                        89L: parts
                          what is the angle of arc the control arm will see? compare that to the max rated of the heim and you'll get your answer
                            Well after digging through my email so I could figure out what they are it says 14*. I figure maybe a inch of travel at the wheel which according to my angle gauge is 20*. The tubing I'm using for the bolt is slightly smaller so it acts like a misalinment spacer. I measured it at the most angle it'll allow and it's 20*. I'm thinking I'm just going to try it with the tube welded and if the link is binding I'll just try to find a rod end that allows more angle.
                            01 saab 9-3: daily
                            89L: for sale
                            89L: parts
                              I just went ahead and welded it. Seems to move smoothly through full travel
                              At full droop
                              Full compression
                              01 saab 9-3: daily
                              89L: for sale
                              89L: parts
                                New bracket and old sway bar bracket.
                                Finished the other side.
                                01 saab 9-3: daily
                                89L: for sale
                                89L: parts
