Originally posted by XelderX
View Post
XelderX's '88 323 Wagon
Originally posted by wgneyz View Posthey man i can sort you a cluster from over here but it will be in km/h though
The car seems to be running perfectly. I haven't had any engine problems with it since getting a new distributor.
Just a little update. Things are still going well and I haven't had anything happen that has left me stranded since replacing the disi. It looks like I'll have to replace the catalytic converter though. There is a pretty severe rattle coming from that area of the exhaust and it doesn't appear to be a heat shield. The rattle is worse when the car is cold and it goes away when the motor is reved up or under load. I haven't had a chance to confirm where it is coming from, but hopefully I can crawl under there in a few days. I'm pretty sure the cat is original but who knows. I have been hoping for a little better fuel mileage and power out of this swap that didn't happen so I'm hoping the cat might be a little clogged. I've been averaging 26-27mpg, but was hoping for a little over 30mpg. I know the F series trans wasn't really geared to do 75mph very efficiently which might be part of my lack of mpg.
I got the cat replaced today and I'm so glad I did. The original cat on the car was completely trashed inside and part of the honeycomb had broken loose and was turned sideways in the chamber. Not very good for flow. The car now has much better acceleration and I can't wait to get a full tank of fuel through it to see how much better the MPG is.
She is still running really good. I had to fix a small exhaust leak last week, but nothing major. I'm still working on the suspension and will hopefully have new front shocks and rear brakes soon. I also found out the gas tank is leaking right at the seam. Just a small drip when it's hot outside. I'll climb under there this week and see if I can epoxy it.
I'll try and get some new pictures. Especially of the new motor. I haven't washed the outside of the car in several years, but it actually doesn't look that bad except for the wheels. I've been so busy with the race car that the wagon has definitely been neglected lately.
Originally posted by wgneyz View PostHey man anymore updates
