Member of MX-3.com
I don't know what power to expect from any of this... but I'm gonna say 150hp before turbo, and maybe 250hp after turbo... I'm looking at a Garrett GT2560 or GT2860.
But I know that if you go more bigger you get more lag... so I'm not sure.
That's not polished up, it's just ported with a burring tool... so after that I'll polish her (exhaust side) up nice so that the gas can get the hell out ASAP. For the intake side I plan to do the same, but then reglass bead the port again to create some turbulance as the fuel and air like that.
I'm still stuck on what specs to get my cams ground to... Other thread. I might go with the Bullfrog/Gude specs, if my cam grinder suggests something else.
Member of MX-3.com
I forgot to mention those Axis Maglites are only 14lbs each and they're 17's... not too shabby. Too bad they don't make them anymore... or are not in production.
Oh yeah I found my old website I made... I should really start up a cardomain page for it.
Member of MX-3.com
Damnit, I shoulda got a Protege... and I woulda saved myself $100.
Oh well onto other issues... I have to drill a hole for the turbo oil drainback in my oil pan. I've found out where the GTX and GTR have theirs tapped in...
I looked at my pan and it's about an inch thick... seems like a good place and it's above the oil level.
Member of MX-3.com
welcome. thats a damn nice build up. vids better come.
That's when I first started searching for wheels like that... when I saw X-Men, and Axis was the only manufacturer that made 4-star wheels. I had to have 'em...
As for progress... car insurance comes up next month so there won't be any purchases... but I might get my valves that I ordered a month ago. Just porting my head for now... and might get my block bored and my crank ground.]
Member of MX-3.com
Does anyone know if you run a GTR intake manifold before I put on the turbo, will it run worse than the stock EGT intake manifold?
I wanna put it on cause I don't want to replace the manifold when I put on the turbo.
Oh yeah, if anyone can answer this, what fitting taps into the oil pan for the turbo oil return line? Is it a 1/2" pipe thread? I need to know what size hole to drill and tap.
Member of MX-3.com
From what I have heard using the GTX manifold with a NA motor seems to pull the same if not a little harder. I however, do not have dyno proof. And keep in mind that the GTR manifold is of much better design.
