tommoro
Rebuild of my bp
Originally posted by TREVO123 View Posttommoro1993 Protege LX-Midnight's shadow SOLD
i don't like the way that "for sale sign" looked @ me---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Can those of you who bought the ebay gasket set comment on the quality? I'll be doing a rebuild myself pretty soon and am looking to do it on the cheap.
Generally I tend to prefer OEM gaskets, but not at the 280 or so I've seen them for. Hell, I think the complete gasket set for my Vr-4 was a few bucks less than that.
Clint1994 Mazda Protege DX (261Kmiles): Eibach springs, Tokico struts, Addco sway bars, massively ghetto-fabulous OBX camber bolts set to max. -ve, Energy Suspension LCA bushings, disc brake conversion, Carbotech XP8 (front) and AX6 (rear) pads, ATE Superblue, 15x7 Kazera KZ-M w/ 205/50/15 Avon Tech Ra (track), 15x6 Miata wheels w/ 195/50/15 Hankook Ventus R-S2 (street) and 14" stock wheels w/ Blizzak WS-60 (ice racing), A/C delete, BP swap, POS Pacesetter (w/ leak), 2.25" custom exhaust, cage and full SCCA ITA prep possibly in the works...
1995 3000GT VR-4:Tein Flex, 332mm Stoptechs, manual steering conversion, custom brake lines with cockpit-mounted prop. valve, AWS delete, DSM sidemounts, full ATR single-exit, 13g/9b mismatch w/9psi WG springs, DN o2 housings, SAFC, AEM wideband, much more, etc.
1987 BMW 325is:Bilsteins/H&R Springs, very solid motor mounts, 220k - stodgy daily driver
the gasket kit is of decent quality, the rubber is Viton so its top quality the gasket looks just as good as the oem one.
Im going to use it on my engine---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Postthe gasket kit is of decent quality, the rubber is Viton so its top quality the gasket looks just as good as the oem one.
Im going to use it on my engineEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
it says viton® right on the packages.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
oh. sounds like these may be higher quality than the felpro kit i got, the front and rear main seals just said "national" on them. lol
um yeah. felpro isnt' very top quality---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
