Originally posted by frogi323
View Post
EGT Group 2 Rallycar Build
nice hood. i have thought about lexan windows for the longest time. but its so damn expensive1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
Thanks! Pulled the cage out---built the bolt in escort cage---pulled it out and put this one back in---welded as much as I could reach---pulled the boxes/plates out and lowered it down to weld all the tops. These are pics of it going in for the final time---lot's of bracing/gussets to make it rally safe/legal!!!
that cage looks awesome.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Thanks! Rally cages are my favorite to build---way more requirements make them much stronger/safer and of course they take more hours to build. Getting everything to fit tightly becomes more of a challenge as well...Here's an EVO 8 rallycar we built---a crazy amount of tubing, but you feel like superman when your driving inside...This escort will be much safer than the evo as even still the designs have become better/stronger---plus the escort is a 1000lbs lighter...
Work looks top notch!
What metal are you using? I'm assuming you're MIG welding it all? When the chassis is certified, are the welds sonic tested or is it all visual?'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
It's DOM and it's all migged except for the sheetmetal plates and boxes---they're tigged. I issue the logbooks/due the inspections for NASA"s rally program here in southern california so it's easy when I build the vehicle...When I logbook someone elses we just visually inspect the weld quality, drill holes to check the wall thickness, measure to make sure the tubes are in the proper locations, and try to make sure that the welds are 360 degrees around all the hard to get area's...I'm pretty easy going as a tech guy, I want the people to have a good experience and get to race each event so it would have to be pretty un-safe before we'd keep someone from racing---and even still we'd help them fix it before the event started.sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
Got the rally suspension yesterday from Hotbits---Jrally helped develop these gravel dampners!!
sexy!!! whats the spring rate?-Jack
Hey Jon-dual rate front and rear-I'll check the rates tomorrow and let you know---we had to drill out the holes in the clevis to get them to fit---we need to explain to them about powder coating! I'll shoot some photo's of them tomorrow installed and post them up.sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
