look around for a nice P/S fluid resevoir who knows you may find a nice one.
Mazda_Powered's 91 Protege LX
yea im gonna try to clean it up as best as i can...worse case i'll boil it lol.
But i'll be running the Escort LX coolant and washer resevoir so i'll have more space for my intake piping on the left side....
The washer resevoir mounts against the firewall and the coolant resevoir mounts where the old washer resevoir was in the right fender pocket.-Jack
well it's 6:20am here ans this is what the front of the front pipe looks like...you can see the difference on the flex joint lol. go vinegar!
other end is in, then i'll clean it up as best as i can, then spray bomb it high temp flat silver probably...same with the n/a exhaust manifold eventually...or i'll have it sandblasted lol, its pretty bad.
I wonder how bad the vj-20 will be with the stock exhaust lol, think it'd melt the cat?Last edited by Mazda_Powered; 03-22-2010, 05:25 AM.-Jack
Originally posted by Mazda_Powered View Postwell it's 6:20am here ans this is what the front of the front pipe looks like...you can see the difference on the flex joint lol. go vinegar!
I wonder how bad the vj-20 will be with the stock exhaust lol, think it'd melt the cat?Cincinnati, ohio Bengals for life
"Who Dey"
Originally posted by viper_707 View Postwill the vinegar do anything to rubber?
you use vinegar to clean out kitchen and bathroom appliances, like dishwashers, washer machines, ect-Jack
i bet that doesn't smell as bad haha, i should try that...but vinegar is so cheap! $1.99 for 4L!-Jack
well its another crappy day outside, no worky for jack
have a coffee can of hardware sitting on the stove in vinegar, so i'll have LOTS of nuts and bolts for the re-installation of everything...i just changed over the solution this morning and they're about 80% clean.
also ordered a SS clutch line with red coating for $25 shipped-Jack
just the bay for now, i wanted to get the car ready for its drivetrain...i think i'll slowly work on the body over the summer...but paint won't come til next year unless i get a good deal lol.
Also got the power steering lines installed, i've decided i'm going to paint the lower 1/2 of the reservoir black, so that'll be installed tomorrow probably.
also fuel filter and brackets, charcoal canister bracket, and a few other things.
Here's my ghetto hood release mod, its bent to the perfect place and works like a charm! Reason for this is the difference from the 90-93 hood VS the 94 hood.
Also started tucking my harness! Left fender harness almost complete. The fuse box wiring is all in the car and at the needed length to reach the glove box
Ok well I'm going to try to finish the left fender wire tuck tomorrow, I've already modified the glove box (yea i know, i said i wouldn't...) to house the fuse box and modified the cover so it just snaps on instead of swings. No pics atm...it's all in the car.
I've just got to make sure i've got all the fuse box wires inside the car before i button it up...so i'm off to the wreckers to take pictures and ID various plugs.
Also since Joseph removed the a/c stuff behind the glove box I've got to pick up the non a/c piece tomorrow as well so I can assembly the dash and leave it lol.-Jack
i just found some 0g wiring so i can use that for my battery + and - since the + will need to be extended from the glove box to the battery's temp location (trunk after safety)-Jack
