Feeling pretty hopeless right now. I took the starter to autozone and had it tested. Everything checked out ok. I put it back in and checked the power, got 12v. Checked the ignition wire, got 12v on that when it's switched. Started It with a screwdriver between the terminals but it still won't start with the key. I'm at a loss.
New Here/New Protege
possible break in the trigger wire? (the flat spade connector)
Yea but it's getting 12v. There are only two wires going to it right? Trigger wire and battery cable. My only concern is that the trigger wire is getting 12v when the key is in the on position. I don't really get that, I would think it should only get 12v when it's in the starting position? I think I'm just going to get a push button and run two wires up so I can start it. Right now I just need to drive it.
have you triple checked all of your grounds? the main ground point on the transmission will cause it to not start. If you haven't changed anything with the wiring it will start.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
awesome, glad you figured it out!-Jack
Well the car is running and drivable. I replaced the pcv valve but it still stalls at idle. Also the car feels like it doesn't have any power at all. I took these two videos while driving.
This one I'm driving and both times when accelerating I'm at full throttle in second shifting to third.
This one I just started the car. I need to press the gas when starting and it idles really low, however I have the idle screw backed out all the way. If I let off the gas it dies.
wow ya that seems real slow lol.
it wasn't doing this before your swapped the trans, was it?-Jack
ahh, understood. If it was a gasket/belt job then I'd check your timing at the gears and then make sure the disti is adjusted more advanced than retarded.-Jack
Well I advanced the disi all the way and it runs a lot better. My guess is some néw plugs and wires will help a lot. That cap and rotor are shot as well. But the motor is doing great, no leaks and runs pretty smooth.
Same butt test. I feels really restricted above 6k. I this because of the stock intake system?
ya car still seems real slow to me. Also if you're distributor is fully advanced, there's a problem lol. You're probably running over 20 degrees of timing right now.
I'd check your timing belt and make sure it's lined up...your intake cam might be off-Jack
