I tried hooking it up all different ways. It is run directly to the small vacuum nipple on in between the motor and throttle body on the manifold. even if i half throttle it it does the same. So essentially at any psi it will do it. Just specifically the car wont rev under any sort of load past 4k.
Gambit's 93dx build
Originally posted by Mazda_Powered View Postif your FPR was hooked up backwards, the car wouldn't run lol.
18psi with a vj20? might be the issue tho, try to dial it back to under 15psi and see if it happens again...probably maxing out the injectors lol
I'd check your wastegate actuator, the internal gates on IHIs are garbagesigpic
92 240SX: KA/T25, nerd mobile
hmmm, running the 4 wire tps?
those plugs should work fine btw-Jack
Bingo. Hook your wg up.1993 Protege LX-Midnight's shadow SOLD
your wastegate isn't hooked up? lol that'd be your problem man!
add a vac nipple somewhere and continue on lol, unless you want me to send you one of my "fancy no-welding necessaries barbed vac lines"-Jack
