Lowering my 98 Protege...
    pics of wheel gap...
    springs and shocks
    cut coil
    check it out...
    http://www.yarilswork.com/
      had a spare hour, so i went ahead and cut the rear springs, 1 coil. i think ima leave it as is for now. its not slammed, but its now noticeably lower than a stock one.
      ill try and post a pic tomorrow.
      check it out...
        so you put in lowering springs, new struts, and then cut the coils?
          yup. didnt like the ride height so i cut 1 coil of the 4 corners.
          this is how it sits now with a full tank of gas. im satisfied.
          check it out...
            looks good
              what springs did you go with (the ones you cut) tylordurben?
                thanks.
                yeah i used the red B+G springs 2.5" drop (they are pictured on this thread) and I cut 1 coil off the bottom on each of them.
                check it out...
                  Originally posted by tylordurben View Post
                  thanks.
                  It looks good now but me personally would never disrespect b&g springs lol
                    thanks, if the product needs modifying so that i can be happy, then so be it.
                    check it out...
                      How much lower did the one coil drop it? Do you have nearly identical pictures so i can compare? I like the final product, if it isn't a bit too low I would just like to see more of what it looked like before you cut the coils.
                      (I saw the other pictures and was just wondering if you had any more)
                        the one coil added .75" drop on the front and .5" on the rear.
                        sorry all the pics I have are posted on page 3 and 4.
                        check it out...
                          Is the ride quality still acceptable with the cut B+G springs?
                            rides just fine. no rubbing no hitting anything and its firmer than stock but not race car firm.
                            check it out...
                              well, thought i would finally post a pic of the 1.5 coils cut up front, im still not completely satisfied with the stance but it will do for a while...
                              Yaril
                              check it out...
                                If you wanted a lower drop why didnt you go with a gold line or intrax spring?
                                Beater=/= Sleeper
