Got these today.
    what are you going to do for a rear sway bar?
    Beater=/= Sleeper
      Powered by ACME
        lol
        i know where you are going with this ...
        I do also have one of the Mazda Motorsports adjustable rear sway bars.
        Powered by ACME
          WTF? I thought the rear struts wouldnt fit?
          Originally posted by firelizard View Post
          Greater challenge on brake upgrade? How so? You going to use BG knuckles?
          edit: oh, I see you were
          Wouldn't fabricating new lower mounts be an easy fix?
          Well Lizard i was gonna use BG spindles untill i realized that the Konis wouldnt fit in them.
          Today i dug out my rear EGT spindles and for ****z checked to see how they would marry up to the BHA GR2 struts AND THEY LINED RIGHT UP!
          I thought maybe there was a difference in camber between the struts and I cant see one .So for me its game on with the bg spindles from the EGT and the GR2 strut bodies at least for the rears.I dont have front spindles from the EGTto compare right now.
          Pictured here is the EGT spindle on the GR2 strut with a BG strut body.
          Powered by ACME
            awesome progress, keep up to date & let us know as things come along take & post many pics
              Update 2 strut bodies done.
              Spent the day with my die grinder.I did the rear one first being overly carefull then when i saw how KYB built them i did the front one in a fraction of the time.Cut a groove all the way around about halfway through the knurled area and the strut will come apart with some tapping.
              To get rid of the factory perches just grind through the 3 welds that secure it to the strut body to weaken the welds and knock the perch off with a hammer,grind the excess weld off the body.
              The height of the Konis look ok in the tubes.
              Next i have to secure the inserts in the bodies and dream up some kinda perch for the ground control adjusters.
              BTW i measured the existing strut length in the car now which has ghetto drop springs over stock struts and its approx 19" from the top of the upper mount to the bottom om the strut body.The height that the car sits is ok for me. I will use this as a reference when welding in the perches on the GR2 bodies.The only real problem is that the droop on the Ground control/eibach spring is an unknown.I believe using an adjustable perch with spacers will pay off large if the car sits too low/high upon install.
              The Koni Part numbers im usin are 8610-1436 Race and 8610-1437 Race.
              Attached is a link to Koni catalog.
              Powered by ACME
                So basically, its a regular spring, but will a coilover system? Werd.
                  Help(er) has arrived!
                  Props to Paragon Porsche for getting these to me super fast!!
                  Also pictured is the proposed solution to perches for the Ground Control spring adjusters to sit on.I have ordered 4 of the 2 inch ID steel single split
                  shaft collars and 4 aluminum solid collars which i will turn into "buckets" for the coil over adjusters to "sit" in.The aluminum ones will sit on the steel ones.
                  The helpers will sit beneath the eibach coilover's ,thus i need a solution to keep the springs together.I know there are couplings available for this purpose but they are costly so im gonna see what i can come up with first before getting them.
                  i think i deserve a beer now.
                  More later...........
                  Powered by ACME
                    the helpers are flat!!!! how crazy. awesome update!!!
                      Originally posted by Beerizfood View Post
                      lol
                      i was asking in regard to how your going to mount it running bg rear struts.
                      Beater=/= Sleeper
                        Thanks!These helpers will spend most of their time fully compressed and ready to take up any slack presented to the strut/springs keeping tension on the main spring at all times.
                        Powered by ACME
                          My apologies for assuming you were tryin to sell me ur rear MMS bar :p
                          It turns out that the inserts dont quite fit in the BG tubes(really close might go with major honing)
                          The kyb,s i "dissasembled" were from a 97 which have BHA factory sway connections allready on them.BTW the BG spindles bolt up to the BHA GR2 strut bodies without mods.
                          Powered by ACME
                            Are you worried at all about rusting of the collars... dissimilar metals? I would assume they're clear anodized
                            95 ES
                            05 S60R
                              i dont think i have any more rear MMS bars.
                              I do however still have a stock one or two.
                              Beater=/= Sleeper
                                The steel collars are black oxide and once i get the base height set,i will paint the strut body and steel collar as one .This is a good point you have brought up though, and a rubber isolater between the aluminum collar and steel one would be a good idea.These collars can be had in SS but are fairly expensive.
                                Powered by ACME
