doesnt canada have its own version of harbor freight?
Got these today.
Beater=/= Sleeper
Originally posted by Kitty View Postdoesnt canada have its own version of harbor freight?
Because the origional seller on Ebay looked good to me ie 100+ feedback and seemed experienced i went ahead and ordered some tooling and stuff for the sherline.Powered by ACME
I always feel iffy about big ticket items from ebay.
Busy bee tools. Lol.Beater=/= Sleeper
Those plates look awesome man. But keep in mind that the extra height added from them is above the top of the strut shaft, so any lowering you do to compensate for it is going to reduce strut travel. I tried lowering mine 1/4 to 1/2 an inch after installing Cusco plates and couldn't deal with how the car hopped through turns afterward.Not the sports page Not a magazine
Originally posted by Hadoken View PostThose plates look awesome man. But keep in mind that the extra height added from them is above the top of the strut shaft, so any lowering you do to compensate for it is going to reduce strut travel. I tried lowering mine 1/4 to 1/2 an inch after installing Cusco plates and couldn't deal with how the car hopped through turns afterward.
I will get my head around this and possibly modify the design to bring the strut shaft up higher but not through the hood .
im gonna try incorporating a caster plate and if it sits on top of the main plate then the shaft length will increase.Powered by ACME
Badass!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by Skuce View PostI see 2 stepper motors there. CNC lathe right out of the box??
I have a 3 axis stepper kit for the mill to install later.Actually 4 axis with the rotary table.
I injured my knee at work and Mrs Beer said ATV had to go so this is my new "safer" hobby.Powered by ACME
Originally posted by Beerizfood View PostI did a little more digging and the cusco mounts use a code H pillow ball nut which is 12mm. The Konis use 14mm
Also the springs are 2.5" ID,just wanted to clarify that in case you are
researching1997 Protegé ES: The Power of BP
Broke Status FTW!
Originally posted by Henchman View PostFrom talking to some CBA Lantis people, you can request a 14mm pillowball nut from Cusco when your order your plates versus the 12mm standard one, which won't fit.
I ended up using cone spacers and a regular nut to do the job of the pillowball nut,luckily the koni,s have plenty of thread at the top of the shaft.
On a side note i finally have enough tooling to start machining the plates.
I will post some pics of this process (if it turns out OK
The biggest problem is holding the work to mills tooling plate.Powered by ACME
Update "down by the old mill stream"
I know it has been a while since ive updated this thread.I have been really busy and had no time to work on the car and getting the mill up and running with tooling etc has also taken more time than expected.
Today i finally got "things" going and milled those "village bicycle" slots
in the other upper plate .
I am well pleased with the results as i have no experience with a mill.
I have to make another plate for the one i ruined .Powered by ACME
now that looks awesome!! whens mass production start---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Thats going to have a ridiculous amount of camber adjustment.
Hopefully they'll work out and wont give you some crazy caster angle.Beater=/= Sleeper
