a few things:
you ideally want 440 stainless steel ball , you want the camber plate slotted & the bearing insert hole drilled in a line.
the nut that goes through the bearing & tightens the strut in place must be of mild steel or harder. you cannot use aluminum. you'll pull it right through
ryan is there a diameter difference from BF-BG strut shaft tops? if not then just get normal ones
