so what are the advantages/disadvantages to the EDIS?
B6t swap
no not realy. not much in my buget just freshing it up and get it running. Then turn up the boost(I need to find a safe level of it). The rebuild is going to cost me about a grand or so i think. But i do plan on putting on a large exaust. What size is a good size do you think. Also when i am done and get some more money I will probalby get a larger turbo. I also will probalby get a FMIC before i start driving it.
most of the BG GTX guys go with a 2.5in, and the GTR's go with 3in.
2.5 should be fine if you have the boost turned up, although I can't be sure since my knowledge of the b6ts is limited. What turbo is planned for the eventual upgrade? If its a rather large turbo, then you might consider upgrading your piping @ that time as well.Last edited by D323; 07-10-2005, 12:13 PM.
Cam seals
Distributor O ring, Intake/exhaust manny gaskets
TB gasket
Front and rear main seals
Timing belt tensioner
It would be best to keep the piston/rod combos in the same cylinder.
And........ Yes it does matter if you mix up the lifters. They should be put back in the same place. Unless ofcourse you get new lifters..... But otherwise they should go back where theyt were found, something to do with the wear patterns on the lifter and the corresponding cam lobe.Ryan The middle child is always ignored
