I Need Help With My MS 1
'95 Ford Escort LX, GTX block .40 over, wiseco 9.1 pistons, gtr rods, gtx head, MS1, 550 inj. T3/T4 .57 Trim, DSM BOV, WALBRO 255 FP, civic half rad, MSP LSD, stage 3 kyclutch, ebay short shifter, mx-3 rear tie bar, AEM wideband....SHE IS ALIVE
'88 Mazda Gtx AWD B6T engine Ported head, VJ-11, EL prototype chipped ECU, Blitz SBC-iD electronic boost controller, Full HKS exhaust, Centerforce dual friction clutch & more
yea thats what i thought too!! yea they are stock gtx 360 injectors!
yes sir i will try that!! i will not be able to do it till sat i have to dj a wedding party tonight after work!
ok i datalog'd it it didnt try to start at all this time........ how do i post up tha data its very big??
this is cut in 1/2 hope this can tell you whats wrong thanks alot
ill check the air line....
the timing was on point with the timing light.
i think he steped on it once.
vac line is good runs right in the back of tha mani.
yea throttle was closed......mmm ill check the cams "I" should be up in the back and "E" should be up in the front right?
witch one is the vac on the datalog? so i can check it........what should it read? thanks alot for your help lex!!!!!
