i did my wiring harness using the pictures/instructions on jacobs website (before he made it password protected... kinda lame IMO), and i didn't have any issues. if the pump isnt working and it worked fine before i'd check your wiring harness.
I Need Help With My MS 1
yea J.B. made my harness but the only way the pump would work before is if i run a jumper wire to the white/red wire in the F.P. relay. i tryed doing that now but it dosent work?????? well atleast im gettin closer to having my car back!!!
'95 Ford Escort LX, GTX block .40 over, wiseco 9.1 pistons, gtr rods, gtx head, MS1, 550 inj. T3/T4 .57 Trim, DSM BOV, WALBRO 255 FP, civic half rad, MSP LSD, stage 3 kyclutch, ebay short shifter, mx-3 rear tie bar, AEM wideband....SHE IS ALIVE
'88 Mazda Gtx AWD B6T engine Ported head, VJ-11, EL prototype chipped ECU, Blitz SBC-iD electronic boost controller, Full HKS exhaust, Centerforce dual friction clutch & more
well im getting power to the light green only if i run the jumper to the white/pink wire and also without the jumper ran to the white/pink wire the M.S. dosent come on? im so lost dose anyone have the wire'n diag for this wire so i can see why theres no power with the key on? the Fuel injection relay under the hood dosent click either should it?....do you think that it could of went bad? and would this make it so there is no power to the white/pink wire? thanks for all the help!!!!
let me find the thread i made up about my problem
ok got the problem with the white/pink wire fixed tha fuel inj relay under the hood went bad......... so with that said im getting the 12v to the ms when i turn the key on...........now the problem the fuel pump is still not coming on???.........im getting 12v to the green wire in the fuel pump relay but im not getting any power at the fuel pump? any one have any ideas?
its not clicking when i turn the key to the one pos.
is there a way to tell one is bad? i have 2 of them i have swaped them out with no clicking from both
im getting 12v to the wire/pink wire and im getting 12v to the light green. what should the black and pink wire be putting out?Last edited by vabreaker20011; 06-04-2008, 06:40 PM.
anyone???? i just need fuel!!!! hahaLast edited by vabreaker20011; 06-06-2008, 07:30 AM.
What is the fuel pump diode?
as far as the inertia switch goes should i only have power in the BDL(what color dose this mean) wire?
dose the b/pk plug into the M.S.?
*LEX* i have done that and it starts right up......... dose this mean my relay's are dead?
