yea i know it was just a thought
tuning & management help
smoke. do yourself huge heaps of a favor...... remove everything MSD & return to stock ignition system. install a RX7 B code VAF if its not running one. & get rid of the SAFC. using one of those runs worse then just factory parts & alters timing.
the bp26 ECU works just fine with 460cc's only if your running the B code VAF & some mild changes to the clock screw settings.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
i have a b code i could sell youEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i dont know, i dont really believe it but if you want to try it you could have it for like 50 bucksEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i dont run an msd, just an msd coil. the msd box only works below like 3k rpm anyway.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
iirc vic had the MSD in so he could run launch control on it"Discontent is the first necessity of progress."
ah, well then that might be worth it
except you can to do that with MS extraEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by therieldeal View Postah, well then that might be worth it
except you can to do that with MS extra"Discontent is the first necessity of progress."
