woot 3002 posts
tuning & management help
Originally posted by smoke187 View Postlol
what if i put in a gtx rail to drop the cc's of the injectors a bit could that work as wellsigpic
92 240SX: KA/T25, nerd mobile
you want the LX FPR.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
all depends what wiring was done. not sure about the charge light persay.
I don't have an a/f guage. my wideband isn't installed yet either---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
easiest way to tell if the CEL is actually showing a code is jump it like you would a normal BP05 and see if it flashes a code. if it does not then theres something else wired to it or a short."Discontent is the first necessity of progress."
Originally posted by smoke187 View Posti thought that you could read codes with one of the gtx ecu's or something like that"Discontent is the first necessity of progress."
the only way the CEL light should be lit is if its wired improperly. pin 1E isn't setup as an output/input on the GTX ecu @ all. I set my harness's up to light the CEL when the boost light would normally be activated from the gtx ecu.
move pin 1E in the harness to pin 2R. & you want move the pins in the back of the cluster plug to move it to the top rather then lighting the check engine light as a boost indicator.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by whistler View Postso how do the JDM's do CEL?"Discontent is the first necessity of progress."
