Good progress!! I still can't wait to see a video of that thing rippin up the streets lol
Pommyvince's BF 323 KL ZE swap
hey vince
man, you've got threw heaps more than what i had to do. Mines running like a dream, apart from reverse left me a few months back and it looks like a whole new gearbox to fix the problem. How far off cert do you think you are now? I cant do anything until i get reverse. I got my hands on another wagon too, fwd 1300 sohc, but thats already out and im on the prowle for something 1600 as well. I minstakley bought a 1800 dohc BP motor with 5 speed box that the guy was 100% sure was only a 1600 but hey its the same thing youve done to fit that in the wag.
have you fit the head lights and stuff you got off me yet, should look quiet tuff but sleeper as?
Well done and i hope to see it drive past one day on the roads.
Not much to report other than now have nice clean cylinder heads with new valve guide seals and recovering from the tedium of lapping-in 24 valves. New rings and big end shells have arrived and I'll plastigauge the bottom end tomorrow just to check I've got the correct big end shells. I'll also run a hone down the bores to give the new rings a good chance of bedding in. If all goes to plan I'll be up and running at the weekend
Finally back together After a quick but gentle drive up the road and down the neighbours drive all seems to be ok with no oil or coolant leaks with a nice steady idle. Which meant it was time to put the panels back on......colour match is pretty good but not perfect.
Just a few things left to do...finish wiring the headlights,stop the exhaust rattling, make a proper air filter bracket, line up the bonnet ( hood) and get the wheel alignment done. Should then be able to get certification ( more money !) and fingers crossed it will pass .
that's bad ass!!!! such a clean job on the rebuild, turned out real nice!
what processes are you taking for breaking in the engine? what oil are you using?-Jack
