EGT worklog
    oh i though you were talking about the block
    "Who Dey"
      Originally posted by Mazda_Powered View Post
      are you rebuilding the cylinder head? you can have a machine shop put it in the parts washer.
      if not, be careful what chemicals and products you use to clean the ports with, don't use anything that could ruin the valve seals.
      if you plug the ports you can probably use a wire brush and brake cleaner for the outside...but for the inside of the ports you can use a rag and some laquer thinner, just keep it away from the valve seals.
      Well I was hoping to just keep it together and clean the carbon off the ports like some of the picks I've seen in other builds. The head suppose to have only 56,000 mi. on it, but I don't know with all the carbon build up. The one port looks like it was hot compared to the others( more black residue).
      I'll post some picks of it to show what I mean!
      91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
      95 Probe SE- Sold!
      The rest is bone stock.
        See what I mean?Click image for larger version
        95 Probe SE- Sold!
          I have just used a wire wheel in my cordless drill to clean the combustion area/valve faces many times. You should keep the drill moving and dont put very much pressure on it, so you dont remove any material from the head, but dont be scared by this statement because you have to really be trying to actually put gouges in the aluminum with the wire wheel.
          FS Forged H beam rods
          awaiting test fit
          Aluminum CAS/Distributor caps
          BP oil jet eliminators
          EV14 fuel rail spacers
          More stuff coming soon.......
            Alright, it's deffinately worth the try!
            95 Probe SE- Sold!
              Update!!!
              Well I decided to go the professional route and went to my buddy's Machine shop that he takes all his Honda stuff to. Don's Racing and machine shop here in Harrisburg. I got the head back from them today after they pressure tested, cleaned up the surface, Ported and polished the head. It looks great, will post pics this weekend ( Camera needs a new battery). I also picked up my new valve springs and valve seals, and finally found a set of head bolts that I could afford and picked those up to. Now I'm finally ready to resume my EGT build!!!!!!!
              95 Probe SE- Sold!
                Here are some pics I promised:
                95 Probe SE- Sold!
                  Heres some more things I have acquired for the build:
                  95 Probe SE- Sold!
                    Does anybody know how to put valve stem seals in?
                    Putting my head back together and I'm not sure how to pop them in.
                    I didn't take thew head apart so I have know clue. Also, how do you put the valve spring retainers back in if you don't have a valve spring compressor!
                    95 Probe SE- Sold!
                      Use a socket to push them in, I think it was a 10mm socket that fit perfectly. Just gently push until they snap in place.
                      You can't.
                      --Ferdi
                        You can't.
                        --Ferdi
                        So I have to get a valve spring compressor?
                        95 Probe SE- Sold!
                          95 Probe SE- Sold!
                            Yes. It's hard enough to do with one, I have never heard of installing the valve keepers without one. Is the head on or off the block?
                            --Ferdi
                              Why didn't you get the shop to put the whole thing back together? Probably would have been way easier.
                              Lookin' to boost my BP. Any help at all on this subject would be benificial to my success.
                                --Ferdi
                                It's off the block, my buddy completed the intake side I just have to put the exhaust side on. He had to stop in the middle of the rebuild of head cause he has an emergency back in Puerto Rico. So I don't know if he has that tool or if I can use it!
                                95 Probe SE- Sold!
