Originally posted by DerekEscortGT
View Post
EGT worklog
91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
The rest is bone stock.
Got he head back together and got he valve spring retainers back in. I had to call my friend who's still in Puerto Rico. He said that he didn't use a valve spring compressor to get the retainers back in, He just used a sparkplug socket and put the retainers inside the spring top and put a 2x4 under valves and pressed down hard till they popped in. I tried it and it worked!
Have this saturday scheduled with my mechanic to do the install. Will take pics as we go. Thanx for everybodies input and knowledge.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Well got started on the rebuild on Sunday. The teardown was easy, and swapping everything over from the the old head over to the new head was tedious! LOL! Everything was going real smooth, with no hold ups or problems.........
Here is some pics.
Out with the old!
The block looks surprisingly in real good shape!
Nice beer holder!!! LOL!
My new head waiting to go in.
New head on. OOOOOOPS AW HE@#!!! Wrong headbolts! DA$% it to HE@#!91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Well we got the head bolts in today, and almost got everything hooked up. Hoping if everything goes well tomarrow, she's going to start up!91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
OK, we're havin an issue and need a little help! Well we have everything together and everything hooked up right(as far as I know).
Now the issue we have is that we can't get the engine to start. The car has enough spark, it's getting fuel to the cumbustion chamber, it's getting air, and all vaccume lines are hooked up, and it tries to start, but it won't start.
Any ideas?91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
95 Probe SE- Sold!
Originally posted by yunvmyegt View Postfuel pump, or cut out switch? does it get fuel with the fuel pump jumped in the diag connector?
Did a compression test on it and found that cylinder1 has 135, cyl 2 has 0,
cyl3 has 129 and cyl 4 has 130. I guess I found the culperate!!! UGH!91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
check the timing marks, but it sounds like your valves arent closing or are bent,burnt? did you replace them or get them checked?.... does that tester allow you to plug in shop air? if so see where its leaking, intake or exhaust side.... you should be able to close each cylinder turning it over by hand....92 protege lx-
94 protege lx-
Originally posted by yunvmyegt View Postcheck the timing marks, but it sounds like your valves arent closing or are bent,burnt? did you replace them or get them checked?.... does that tester allow you to plug in shop air? if so see where its leaking, intake or exhaust side.... you should be able to close each cylinder turning it over by hand....91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Help please!!!!!!!
Well it's not the valves! After tearing it all back down again, we looked better at the pistons and found that in cylinder 2 the piston is melted a little and there is a little blow by. Then we looked at cylinder 3 and again but even less than 2 but still a little mark on it.
Now I have a problem, My friend doesn't want to get into the build any deeper, and I'm not to sure on what to do on the bottom end now with no garage! Anybody close by Harrisburg ,Pa and has the knowledge of the lower end and can help me install new pistons or if the block is bad put a new block in??????? Can anyone help?91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Bump?
95 Probe SE- Sold!
Originally posted by pile_of_rd1 View PostI got a good shortblock I could ship out to you cheap..... if i was closer I would help you.
Is that what I have?91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
