Mazda_Powered's 91 Protege LX
Well tomorrows events consist of getting my Bosch dual tone horns properly restored/painted/mounted behind my grill to "be all hip" and stuff.
Also mounted my distribution block as I'm planning on re-doing the alternator, starter, and fuse box wiring...just need to find my damn ring terminal ends to finish the job...here's the unit before I mounted it with the 4g? wiring I'm using (it's a gauge larger than the stock starter wire lol)
Nice jack!! Pm me a link to those things, I may have to get some lol
1988 323 GT - B6T Powered
PM me too jack!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I'd like to verify they fit and everything works fine first lol, but the "general" part number (not manufacturer specific) is MF106ZZ.
They come in difference sizes, but the MF106ZZ stands for Metric/Flanged/10mm OD/6mm ID/
so if you had a 12mm OD bushing, you could search MF126ZZ, or MF128ZZ-Jack
ah my bad haha, I couldn't remember if it was 10mm OD or ID for the OEM bushings!! I've got too many numbers floating around in my head.-Jack
I was just going to run a spacer in the middle tho Josh, like skateboard wheels! Or I could press in another 13mm non flanged bearing as well.-Jack
yea that's a good point too-Jack
Curious to see the end result of this92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
