Mazda_Powered's 91 Protege LX
    Ya its pretty compact back there with the factory rad but it will fit no problem, thats if your using a factory rad which i think you are.
    if you want you can go with a slim fan if you have not yet.
    I went with the civic half rad but it was like 3in thick and I couldnt fit my fan as a puller had to use it as a pusher. hated it.
    I would stick with the factory rad what ever you do tho... its sufficient I think
    93 Mercury Tracer SW
    01 Honda S2000 Future Boost
      Yea stock rad, and I'll be using a slim fan since I'm going with a custom turbo inlet pipe lol.
      I'm gonna try to pick up some 2" exhaust pipe tomorrow, and take the chop saw to it and figure out the outlet pipe. I'm going to cut it at different angles, use multiple pieces, tack it, then bring it off to be welded. No access to mandrel bends locally lol
        Nice work Jack. Now get that thing on the road and really smile
          i know!!! aiming for May 1st! Still waiting on parts to show up in the mail still tho!
          intercooler
          bov/flange
          inlet pipe
          so that's kinda holding me back a bit hahaha. I need to get an intercooler so I can cut the front IC pipes to proper lengths dammit!!! lol
          I think the BOV is the one thing on the list I don't really need right now since none of the piping is permanently mounted and my inlet pipe is non-existent lol
            well bought some 2" pipe today lol about 10ft of it! Can't argue with $20. Anyways I'll be attacking that after this post lol.
            So far I've installed all the clamps on the coolant lines, looped the 2 at the back of the hardline (no coolant is running to the intake/tb ) installed the rad, filled it up and started her up.
            She ran REAL rough, 3cylinders wouldn't idle so I pulled the ignition wires and put on another set that has copper ends, and it idles smooth now! Adjusted the idle screw and timing to OE specs, and it idles at 750rpm
            Feels good to be able to allow the car to idle longer than 10 seconds now tho haha. Just need a slim fan to finish the coolant system.
              Started working on the turbo outlet pipe, and it's coming along real nice! so far I have 6 difference angled pieces cut up, cleaned and marked for welding.
              Once its welded up I can have it welded to the flange, I forgot to mark the flange so idk what angle the first pipe is turned to lol. Either way when It was all taped together, it's no lower than the oil pan so I'm golden!
                Glad to hear you got it running smooth. My bad about the fuse holder. I swear I had some! I just couldn't find it after looking in all the places it should have been.
                Before you criticize someone, first try walking a mile in their shoes. Because then you'll be a mile away, and you'll have their shoes...
                  haha no worries man, I still have yet to go out and get one
                    couple more vids now that the cars running much better, this was the coldest day I've started the car too lol
                    Turbo is still not hooked up, still fabricating the outlet pipe and waiting for my intercooler. Just showing how the car cold starts and idles.As said in the...
                      well the company I had order the ES bushing kit still hasn't gotten them in...it's been forever! I really want to get some front end work started and I'm waiting on them! Well at least the frame bushings! So I ordered some model specific 15/16" frame bushings from RuK productions. They're polyurethane, so we'll see how they hold up.
                      edit: also ordered another 2.5" straight coupler, since I need an extra one to finish my IC piping
                        well the outlet pipe is almost done, decided to try my dads welder today lol, after about 30 minutes of messing with the dials, I was able to tack the pipe together and then welded it together little by little...so lots of chunky welds and splatter all over the pipe, but I started to grind them all down until the pipe got caught and almost cut my finger off in the grinder! If I wasn't wearing my safety gloves It would have ground my finger to the bone!!!! YIKES!!!!
                        Luckily 'tis only a flesh wound!
                          Wow, good thing you had your gloves! That happened to me at work once too. Same thing, my gloves saved my hand.
                            Got any picof the mocked up pipe? And make sure you always keep a good set of work/Welding gloves on as a welder with lots of experience with burns and cuts I highly recommend it good to hear you didn't take your finger of too :D
                            Sent from my DROIDX using Tapatalk
                            1988 323 GTX - "Miss Becky" - VJ-11, Autometer Sport Comp boost gauge, Sachs Clutch, K&N Air Filter. Freshly rebuilt engine with Clevite Bearings, Fel-Pro Gaskets and NGKs, 2.5" Exhaust from turbo back with a Turbo muffler.
                            1970 Chevelle SS - "Krista"/"ALMYDOE" - restored from the ground up, 350/350, lowered 2" frnt 1" rear, flowmaster 40 series, Holley Street Avenger, GMPP intake, American Racing Torqlites. (Ported and Polished ZZ4 Aluminum Heads coming soon)
                              A scratch? Your arm's off!
                                No it isn't! The black knight always triumphs!!
