AWD Turbo Protege Recce Rallycar
    Yeah that pic is deceiving, the seat is back as far as it will go---so with Chuck in there, it's further forward---if I go back too much further, the rear passengers are going to have issues getting in and out.
      That makes sense then. Can't wait to make it out to see in person again. Crossing my fingers for Gorman next month and bringing my recce car out.
      -Jon
        Been a while since I've had anything worth posting---got the parts too build the coilovers---a generic kit, some Ksport camber plates for the front and I've got a ton of Eibach springs around. They're going on top of ford motorsport struts. Also finished up the mainhoop (except for harness bar---waiting to see where the seats mounted for height)---fit's in the protege/escort/323---all the same dimensions!
          Mnnn TSL's and beadlocks ...
            We fit 37's on a Defender 90...after about $10k worth of suspension work---fox coilovers all around, custom control arms etc...nice toy for the guy to play with...
              37 tsl's are a b#@!h ... did some a few months ago.
                you know, I'm going to have to get off my ass and hurry up with my 4WD project. I might have to get two of those, one for my escort wagon also!
                --sarge
                  Got the seats made with custom logo's for the race team---first time I've put a "true" offroad seat in a rallycar...He's racing the escort this weekend by the way---with a new 4.92 final drive in the gearbox!!
                    I rode in an Eclipse, during a rally cross, with Beard suspension seats, not the right car for those seats. The Protege should have a better roof line hieght.
                    -Jon
                      The eclipse isn't right for anyone over about 5'4 to drive---and you have to section the trans tunnel to get the seat centered on the wheel! Finally got the coilover kit's to work on your old Ford Motorsport struts---had to pop the cap off to get the sleeve over and then machine the top hat's for the strut bearing, but over all it worked nicely. Wasn't able to make the Ksport camber plates work though---not enough thread at the top...
                      -Jon
                        Nice job
                          Nice job
                          Thanks! Got almost 8" of travel in the back before coil bind/bump stop---not too bad!
                            damn that looks amazing. how many extra springs do you have lying around? any small sizes for a street car?
                            1994 Escort LX Wagon
                            2013 Hyundai Veloster Turbo
                            91 EGT - Junked May 2012
                              Which Ford Motorsport struts are those? The only one's I've seen are the 45mm inverted damper ones made by Dynamic Suspensions with Hyperco springs. pretty short-travel, too, around 4 inches, made for tarmac as far as I know. I need to hurry up and install them on something.
                              How readily available are the long-travel ones you have?
                              ---sarge
                                ---sarge
                                I may have spoken too soon---they are 45mm shafts (had to open up the hats big time---They seem to have about 7" of front travel and 8" of rear----I wonder if they're ZX2 stuff---JRally knows, I'll ask him.
                                I've got a ton of stuff---have to let me know what rates/lengths specifically you need and I'll look for you.
