Michael0008 bf Etude
    yip will do ,cant wait for the next meet ,as the last one was so mean
    Originally posted by DeeAOne View Post
    awesome man. good to see you got it running.
    yea it is sooo good to hear it start
    etude ftw!
      ok took it around the block
      so many things when wrong
      i think i need a new afm as its not able to go over 1900rpm and it just pulse you back and forwards till you stop accelerating and the rpm doesn't stay at one point at idle
      or do you think ive connected a vac line up wrong too?
      also took the cap off and it was milky
      so many have a blown head gasket too or just a crap load of moisture from being sitting?
      etude ftw!
        oh no!
        the milkcould be a few things, could be the oil cooler leaking...which would be nice
        also the 1900rpm cut could be from a coolant temp sensor. do you know what your timing is at as well? fuel pump in good shape?
          ok soooooo after ages i ended up taking the afm off to see if it cuts out with it out
          turns out that it could idle with no afm WTF (so it was running in limp home mod) thats why it was running mega rish
          so after more time it turns out inside the plug that connects to the afm a wire under the rubber seal was broken so soldered that on and brrrrrrrm brrrrm pessssss
          yea goes mean after timing it , smoke is gone now,and the headgasket is ok now the white **** has stop showing up
          zip tide temporarily fix hehe......going to put better bumper on later
          hmm....
          black around the top has been cleaned up as it was faded and car has been cleaned
          looks weird with no exhaust poking out
          hmm might put the facelift bumper back on
          but don't really like having the intercooler showing
          still got to fix the grill and i am going to put the 3 mesh stuff behind the grill
          also got to fix bonnet latch as its not closing right
          also got autometer cap, to stop my gauge from flying around
          the 3 mesh just didn't look right
          any way so more pictures and a video is that belt noise normal or is it the alternator bearing?
          really need to get a new bar piece as thats crap
          also the plug on the head light loom that has the rpm wire to gauge ect whats the big blue wire do
          also cant work out how to get temp?
          etude ftw!
            got some 22v calipers for the vr4 rotor upgrade
            hopfully it should stop better then it does now
            any upgrade for back brakes?
            also might get rid of the vj20 and put a ct26 turbo on
            etude ftw!
              Use NA6 Miata rear calipers on custom brackets with Galant rear rotors. That way the bigger fronts won't unbalance the overall ratio. Install a bigger master cylinder to keep the pedal from sinking to the floor. You'll have a seriously effective package.
              Scott F. Williams
              Team Director
              Usually Sideways Rally Team
              www.usrallyteam.com
              856.456.3335
                after stuff thats a bolt on job
                so are the mx5 calipers the same mounting hole space
                etude ftw!
                  No, they're not. That's why you need to run custom carriers. There was a group buy on them earlier this year. Do a search and you'll find it. Maybe there are some left.
                  Scott F. Williams
                  Team Director
                  www.usrallyteam.com
                  856.456.3335
                    update: took apart the old b6d engine for the rods for the bpt
                    and made a mess to haha
                    and also got a gtr link ecu ,so bye bye afm
                    etude ftw!
                      update decide to go kfze
                      should be a close fit
                      bpt wasn't my thing and my headgasket went on it too
                      5 stud and better brakes
                      etude ftw!
                        the only way to get the engine in
                        test fit
                        it fits just in some spots
                        next up working out the mounts and if i can use any of the bf ones
                        etude ftw!
                          Nice engine choice. I love the idea of a 6cyl BF. But, which transmission are you using? Can the "K" motor attach to the BF AWD tranny, for instance?
                          Scott F. Williams
                          Team Director
                          www.usrallyteam.com
                          856.456.3335
                            Not without a adapter plate.
                            12 cbr250r: daily ride
                            01 saab 9-3: daily
                            98 gsxr 1100: for sale
                            93L: money pit/ space waster
                            92GL: low and slow beater
                            90?: the rust free shell
                            89L: for sale
                            89L: parts
                            76+80 vw dashers: for sale
                              But, with an adapter plate it specifically will work? Also, what's the weight increase over a B6T or BPT?
                              Scott F. Williams
                              Team Director
                              www.usrallyteam.com
                              856.456.3335
                                you got it! Nice. Yeah I meant to tell you that you kinda have to do some pivoting to get it to drop in from the top. Lol. You probably had even more trouble with your car since its rhd.
                                '88 323 sedan, K-swapped..
