Michael0008 bf Etude
    Not feeling how much they stick out.
      thats because the offset for these wheels is +25 ,also the wheels are just on there so i can move the car around and test fit the axles
      etude ftw!
        Once you get some rims with a different off-set, so the wheel are tucked in the wheel well, it'll look really sharp!!
        1988 323 GT - B6T Powered
          good progress man. keep it up.
          '88 323 sedan, K-swapped..
            tried fitting the other axle and it was too long as you all know.
            any way ive been trying other axles and not much success yet
            got two different axles that ive fitted that can work and correct length but needs a little bit of mucking around to work fully
            the axles ive got is 626 gd rf axle
            its the correct length only problem is the tri-pod type CV joint is a mm too big from fitting into the lantis cv cup and the shaft on the 626 axle is a mm bigger then the lantis axle so the lantis tri-pod type CV joint cant fit on, so might get the spline machined down a mm to aspect the lantis tri-pod type CV joint.
            sec axle i got is a sp20 bj axle
            correct length only problem is the shaft is a little bit small then the lantis one so the lantis tri-pod type CV joint cant fit on and the tri-pod type CV joint on the sp20 is a little loose in the lantis cv cup
            so i think i will use the 626 axle if i can find a smaller tri-pod type CV joint to suit the lantis cv cup
            etude ftw!
              gave up on finding a axle thats the right spline and length ect so getting the axle shorted by a engineer by 4cm and balanced so axle will be done on Monday
              etude ftw!
                well tried fitting the other axle and was 3cm too long
                so ended up getting the axle shorted , tried heaps of axles none seemed to work
                my attempt to make it into a hard rubber mount haha
                after smoothing out ,doesn't look too bad.
                hopefully stops the front mount fall apart.
                more parts to do 5 stud rear
                lantis master cylinder which is alot smaller,so now the engine shouldn't touch the master cylinder
                clutch master cylinder from the lantis .
                fits prefect don't even have to drill a hole in the firewall. it matches up to the two holes from the cable in the firewall
                only need to drill one hole in the pedal then its been converted to hydraulic
                that rod that goes through the knuckle suppose to be on a angle like its bent ,both hubs are like that?
                also all engine mounts are finally finished and have been mod to suit v6
                so its finally sitting in right
                etude ftw!
                  nice! those welded shafts look a lot better than mine. how much did that run you?
                    yea its been tig and balanced
                    um cost $150 nz so its not too bad
                    etude ftw!
                      that is awesome. i really need to find somewhere like that around here. as much as i want non-welded shafts i really dont want to drop $800 either. lol
                        haha yea i know what you mean.
                        so why do you need two axles? my other axle fits fine
                        etude ftw!
                          it fits, but it binds under hard acceleration and hard cornering. bad vibration. so it killed the one wheel bearing that was good. now both front bearings are shot. lol
                            whats binds?
                            etude ftw!
                              its starts to jam up from being too squished, causing the car to shake. this should explain.
                              my driver side (your passenger side)
                                Looks like you're making good progress. I'll be interested to see how you get on with the five stud hubs on the rear.
                                It'd be a good idea to check with your local "certification" guy on whether you need to get that axle X rayed and sleeved...all the cert guys in Christchurch require it on modified axles.
                                What did you use to fill that engine mount ??
