anyone know if the 626 clutch master reservoir just unscrew?
lantis clutch master cylinder doesn't work as the brake booster hits it
good news is a lantis master cylinder and brake booster is a complete bolt up job and you just need to swap the bf fork onto the push rod to get the right length on the booster
also now ive got a 7mm gap between the engine and master so its alot better now
using lantis hubs, offset doesn't bother me as its around the offset i want
Wow, at just 6.2kg/13.7lbs those wheels are incredibly light. That should offset the reduced ride compliance due to the shorter sidewall in a very nice way. Traction will also increase as the rubber stays on the ground more often.
Why the 40mm offset, though? The Etude generally use 45mm like other BFs, correct? Or, do your newer chassis hubs change that? Btw, which hubs/knuckles did you go with to get the 5-lug bolt pattern?
